Results 11 to 20 of 50
Thread: polished or sandblasted valve cover can kill your engine.
    GREASE BUNNY
    VA
    Ok
    I'm feeling kinda sick.
    Iceland / Europe
    Im going to take the baffling in the valve covers off and clean behind it tomorow , hopefully refitting it isnt impossible...
    94 SL | 96 SL | 91 R/T | 93 SL | 94 ES | 95 SL | 92 VR-4 | 91 SL | 93 ES < gone | curent > 95 VR-4
    ............................ AUGUST 2010 RIDE OF THE MONTH !!
    ................................... 2010 RIDE OF THE YEAR !!
    The Big House.
    Quote Originally Posted by IcelandGTO View Post
    Not 100%, but I think you can get away with not reinstalling the baffles...
    Quote Originally Posted by Granny View Post
    Ok
    Why are you feeling this way?
    GREASE BUNNY
    VA
    Everything on my engine has been polished.
    Never thought of this.
    Stewart didn't do anything to the undersides of my covers or blast them but I'm sure he had to sand them off.
    I'm sure there is stuff lurking.
    The Big House.
    If you have the time, I would pull something easy and give it a good thorough look through...
  7. #17
    GREASE BUNNY
    VA
    It's all off the car now and it's getting a good going over.
  8. #18
    Karen, It's mainly when it's been sandblasted, not just sanded but you cant be to careful.
    Wichita, KS
    Quote Originally Posted by Dbeltran24 View Post
    I soda blast with a 8 gallon air compressor and 40 gallon soda blaster. Works pretty well. The setup cost me less than $200 from harbor freights. The amount of force needed to blast with soda is not that much. I usually have the pressure turned down when blasting. If I turn it up too much, I just waste soda. My problem is maintaining constant pressure. Probably going to increase the size of the air compressor, to correct the issue. Currently I have to take breaks every 10 minutes to wait 2 minutes for it to build pressure again. Its not as annoying when doing small parts, but large parts take forever. Soda is much easier to clean up and is biodegradable. I no longer use my sand blasting box, instead I blast outside with a mask. Once i'm done, the area I worked in looks like it just snowed, lol. Luckily it just dissolves in water, and washes away.
    Exactly what I do. It works really well IMO. I just have a $15 siphon gun from Amazon and a 5 gallon bucket with soda. My compressor is plenty large. My only issue is continuously feeding the soda. It likes to create pockets so you need to re-position the pick-up tube every now and then.
    91 R/T TT
  10. #20
    Never finishes any verified
    Wake Forest, NC
    I learned through a bad oil analysis that I had way to much silicone in my engine which came from recently blasting and painting my valve cover. I was too quick in cleaning it out and didn't get all the medium out from under the baffles. I was lucky that I didn't get any large particles in it and that I changed the oil soon after it was blasted.
    I am not much more cautious when running parts that make contact with oil through my blaster. The last oil part I ran though was an oil filter housing. I removed and replaced the relief valve on it and I must have scrubbed it down 10 times after blasting it.
    The next time I do a valve cover, the baffles will be removed as I know that is were the medium was getting in.
    Check it out on Youtube!!
    Chrome ECU
    Hybrid 13g's
    EVO 560cc Injectors
    Spec Stage 3 clutch
    CX Racing Dual Core FMIC
    Megan SS Exhaust
    3rd Gen Lifters
    Maximal High flow converter
    Walbro FP & FuelLab FPR
    All -6an Lines
    AWS/ABS/Cruise Delete
    MP Rear Control Arms
    SS Brake Lines
    99 Front Conversion
    2nd gen Rear Bumper
    99 Combat Wing
    Complete interior LED Swap
    Skillard Fuel channel
    Oohnoo FPR Bracket
    More to Come......
