Page 1 of 5 123 ... LastLast
Results 1 to 10 of 50
Thread: polished or sandblasted valve cover can kill your engine.
    Iceland / Europe
    94 SL | 96 SL | 91 R/T | 93 SL | 94 ES | 95 SL | 92 VR-4 | 91 SL | 93 ES < gone | curent > 95 VR-4
    ............................ AUGUST 2010 RIDE OF THE MONTH !!
    ................................... 2010 RIDE OF THE YEAR !!
    yes, this has been brought up before.
    Flush, flush, flush....
    I did mine in the bath tub, kept doing it until stuff quite appearing. then took them to the car wash and power flushed each one for 3 minutes straight.
    Wichita, KS
    Which is why I will be blasting mine with baking soda...which will dissolve when I go to clean it afterwards. (Assuming previous powder coating isn't too resilient)
    91 R/T TT
    The Big House.
    Unfortunately been down this road... thankfully Ray and the boys discovered it before my car left their shop.
    Sep 2012
    Decatur, TN
    Had a buddy get his brand new engine in his MR2 get wiped out because of this. It's a pity. For steel, electrolysis is the way to go for prepping them. For aluminum, a quality aircraft grade paint stripper and elbow grease.
    Soda blasting is good, but not exactly possible for the average home enthusiast. You just can't generate the kind of pressure needed to really strip stuff well short of commercial grade equipment IMO. The Eastwood (and eBay) stuff doesn't really do the job well enough.
    Iceland / Europe
    got link ?
    TN
    Yeah, I bead blast throttle bodies and plenums... even with blocking everything off I'm so paranoid that I spend 20 minutes with an air compressor making sure nothing got into the ports. I don't know how they think no material will be trapped underneath the baffling of a valve cover.
    Quote Originally Posted by IcelandGTO View Post
    got link ?
    Its been discussed several times on the other site.
    Silver Spring, MD
    I soda blast with a 8 gallon air compressor and 40 gallon soda blaster. Works pretty well. The setup cost me less than $200 from harbor freights. The amount of force needed to blast with soda is not that much. I usually have the pressure turned down when blasting. If I turn it up too much, I just waste soda. My problem is maintaining constant pressure. Probably going to increase the size of the air compressor, to correct the issue. Currently I have to take breaks every 10 minutes to wait 2 minutes for it to build pressure again. Its not as annoying when doing small parts, but large parts take forever. Soda is much easier to clean up and is biodegradable. I no longer use my sand blasting box, instead I blast outside with a mask. Once i'm done, the area I worked in looks like it just snowed, lol. Luckily it just dissolves in water, and washes away.
    MODS - DNP Intake with K&N Style Filter, Polished DOHC Throttle Body with Portmatched Plenum, Portmatched Intake and Exhuast Ports on Heads, Ported Intake Passages in Heads, Performance Valve Job (Street), 3SX WebCams Reground Cams, .20 Overbored Block/Pistons, 3SX Fed Spec Downpipe with Gutted Rear Pre-Cat, 3SX Stock Size Crank Pulley, BigTyla Ground Wires, MSD Spark Plug Wires, Seatlle92VR4's Hyper-Flex Polyurethane Motor, Ultimate Performance Strut Bars, 3SX Polyurethane Suspension Bushings, Shift Kit
    The Big House.
    got link ?
    There's a few threads about it on the other site. Do you have any questions about it? It's a pretty shitty feeling knowing something so stupid wiped out a very expensive motor.
