Bumped the for sale threads![]()
moved it into the garage
Picked up an exhaust and got almost everything ready to pull the engine
"Why pay for a sports car, keep is clean and shiny, mod it, and drive it like a bitch?"
Drove the spyder down the street and forgot why
Worked on finishing my wing adapters:
Active Aero Assmebly - Stock Wing + APR GTC = Active Aero with real downforce
Did some sliding around in therrain going back and forth between work.
Over the past several days - did a full brakes job:
- took out the old brakelines & installed new StopTech SS Brakelines
- Tore down & rebuilt the front & rear calipers (cleaned cylinders , new seals, polished pistons etc)
- installed x4 Russel speed bleeders
- installed x4 new Powerslot Cryo Rotors
- installed x4 new PorterField R4S pads + shims
- flushed and bled the system with new Motul 600 fluid
Favorite Car - A 1998 RED VR4 , pretty much stock except: Suspension: '94 ECS Struts Retrofit w/ Tein H-Techs controlled by TechWorks ECS Suspension Controller
www.renegadetechworks.com Open Source 3000gt ECS Retrofit & Replacement Controllers
