Results 1 to 10 of 28
Thread: closed loop CEL
    VR-3747 :D Not Verified
    Dayton Ohio
    closed loop CEL
    hey guys,
    just wondering if the 98/99 ecu's are more reliant or just more finicky when it comes to closed loop feedback?
    would bad o2 sensors cause me to throw a code for (i cant remember the exact wording atm) "extensive time to enter closed loop function"? i haver never had this issue before until i switched to the flashable setup. now i get it on every startup and have to drive around with a cel unless i clear it.
    i bought some new o2 sensors but i dont want to switch them out if what i have now are fine (i dont think they are, just saying).
    thanks guys
    Your car needs to be fine tuned. The code wants cycling O2s and after so long of driving around with the trims maxed, it throws that CEL.
    Dayton Ohio
    hmm. ok
    yeah it will do this if your trims are maxed or if one of your o2 signals is dead. Please post a log with both o2 sensors voltages.
    Dayton Ohio
    Just to be clear, in order to get my trims back where they should be, I will need to make it run rich for a while (16 mins or so) and hopefully see them come back closer to zero?
    Dayton Ohio
    Chris, I'm messing with the tune ATM. Let me see where I can get here then ill post a log or two
    you don't really have to wait to know if you are getting close. look at the short term fuel trim. It plus the long term is the real trim in action. So, if you are +12 on long term and -3 on the short term then your long term is going to adjust out to +9 after a while. So, try to get the two close to zero, then drive the car for a while and see if it needs further adjustments.
    Dayton Ohio
    how do you know so much man? i feel like all i have been doing is reading about this stuff, but no where have i read that. maybe i did and just didnt know it? makes me feel d-u-m dum.
    or disconnect the battery, because that will set them back to 0...
    Just watched all the evo ecuflash videos, read some of their threads on dialing in injectors, and of course read Greg's stuff. It helps that my job is in computers anyway.
