Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
Thread: closed loop CEL
    I lack color... verified
    Aug 1998
    Also, there is no way to get excel to hide the empty rows. You gotta do it manually.
    This is where Toni's Logworks program comes in handy. Takes the excell spread sheet and plots everything onto a graph.
    Aug 1998
    Quote Originally Posted by Keyan View Post
    when my o2s were swapped, my car wouldn't idle proper, or drive much at all. I doubt this is his issue.
    Based on the log he posted, I agree with you.
    VR-3747 :D Not Verified
    Dayton Ohio
    It's supposed to be the VE look up table number.
    I doubt your o2s are dead. Been telling you for a while now that you need to add a couple clicks to the MAFT as its telling the ECU there is less air than there really is. Thus you are running lean. You keep adding fuel to the intake, fuel and accel tables and it still isn't enough to get the narrowbands to cycle.
    i am going to add some with the base knob, dont worry! i just signed papers for a job with my engineering degree today, and been busy with school. i just havent gotten around to messing with the car as much as i would like lately!
  4. #24
    Aug 1998
  5. #25
    Low & Slow verified
    Fortson, GA
    my trims have grown pretty far apart too. Rear is +9 , front is +1. I am hoping a fuel loop will close them up.
    I thought I was alone and had some strange IM leak because my low trims stay 10% apart. I have dialed them to split the difference at 5 and -5 but I have some new injector gromets for the lower intake and when I do this I will be swapping the front 3 injectors to the back to see if the trims change with the injectors. The mid trims stay within 2 of each other and the high trims do as well. I have pressure tested and can't find a leak to distinguish the front bank from the rear. I did notice in the stock rom that the gain settings for closed loop feedback are a lot different from the front (25) to the rear (3) bank. I don't know if this has anything to do with that or not.
    Jeff
  6. #26
    Aug 1998
    Are you guys sure you don't have a crack in your front exhaust manifold?
  7. #27
    Absolutely sure
    Sent from my RM-845_nam_vzw_100 using Board Express
  8. #28
    Dayton Ohio
    I am pretty sure I don't either.
