Page 7 of 39 FirstFirst ... 5678917 ... LastLast
Results 61 to 70 of 382
Thread: '93 VR4 State of the Union
  1. #61
    Jan 2011
    az
    Glad u figured out how to use the scan master with the laptop. Hopefully I can do the same soon. So the evoscan is logging software. How do you get it to work for the 3s.
    Edit. After actually looking at the last post looks like its setup for the 3s .
  2. #62
    The AMRs hit the inner edge of calipers... these may fit 2g's
    The wheel is an 1/8th inch or less off the hub i guesstimate.
  3. #63
    Man vs 3/S verified
    Kingston, WA
    Damn, I know they fit 2g's, put them on Coopkill's car myself and we rolled it out of the garage no problem.
    Sucks they dont fit, man
    3SNG15 Best overall
    Runs 12's (12.98's!!!!!!)
    My Garage
  4. #64
    Eh. Worst case I eat $150.
    Got some gn+'s to buy local.
  5. #65
    Jun 2011
    Sweden, Gothenburg
  6. #66
    Can you not shave the caliper in that spot or use a spacer?
  7. #67
    The difference in wheel clearance between 1g and 2g tt calipers is insane.
  8. #68
    Jan 2011
    az
    Would spacers work ?
    Ross 9:1 piston, H beam rods with arp bolts, *Forged crank,*Ported head with brian crower 1mm over intake and exhaust valves,*Brian crower valve springs,Oem headgaskets,*Arp headstuds*,T3 hybrid turbos with .63ar,*Tial leaded fuel wastegates with 1bar springs,*Cx racing fmic*,Arc2 in blowthru,*950cc delphis on e85,Jackhammer fuel hanger holding 2 walbros 255 hotwired ,Fuel lab fpr,*Aeromotive fuel filter*Entire fuel system done in ptfe braided black lines,*Beefed up oil cooler,*Gates racing belt*,Ninja performance soild tension setup*,3sx single pass radiator*,Tial q blowoff*,Scanmaster*,Aem twin fire*,3sx fuel rails* battery relocated to trunk, blitz dsbc, aem wideband, autometer oil pressure gauge,And so on....
  9. #69
    I don't bite
    Southern IN
    Why spacers when 2g brake swap is better option since it seems to be turning into a more street oriented car than 1/4mile car?
  10. #70
    Spacers or grinding would probably work, but im not going to try.
    I installed the hella horns (hidden) and fixed the right side horn button. It wasnt grounded.
