Results 1 to 7 of 7
Thread: Barometric sensor fail
    Autozone says the fault is P1105. Car runs fine other than the ck engine light. Don't want to go out and but a new MAS only to find out it's something else. Other than that what could it be, and why is the car running good if it's a bad MAS?
    Feb 2014
    2002 and 2014
    Hamilton, Ontario, Canada
    It's not a bad MAF. It's a bad barometric pressure sensor or wire to the baro sensor, which is contained within the MAF.
    If you drove your car to a higher or lower elevation you might notice that it doesn't run as nicely because the baro sensor cannot compensate for this.
    But if it's in the MAF and can't replace the sensor doesn't it make the MAF bad? LOL apples and oranges I know. What I was getting at is ultimately the MAF is bad due to the sensor.
    Feb 2014
    2002 and 2014
    Quote Originally Posted by curt93t/t View Post
    Technically yes. Lol.
    Is it possible to change just the sensor out? Looking at pictures online there are 2 screws holding that thing on.
    Isn't this code for the fuel pressure solenoid??
    Medford OR
    Quote Originally Posted by First VR4 View Post
    Yes, but it may just be a typo... Baro code is P0105
