I actually did some testing as well and found that with larger duration cams, big turbos, large exhaust 0 is the best place..I could see lower boost big exhaust being benificial with scaveging effects but big turbos at high boost increase the intake vs exhaust pressure ratio (also have to consdier turbine and turbine housing retrictions) and cause reversion. My thoughts are that with an intake to exhaust pressure ration of 1 or less overlap is ok but with higher ratios you will mot evacuate all the burnt mixture. Wish we had cam phasing to bennifit from low boost overlap and then spread them out at hight boost..i guess youu have to find a happy medium and just go with it..
w/DBB DR1000's
