Results 11 to 20 of 25
Thread: Stock Keyless entry troubleshooting
    ~2006
    Pittsburgh, PA/Wheeling, WV
    Are they genuine OEM? Maybe they are just replicas/generics that suck if both don't work and they are from different sellers?
    I never heard that the door had to be closed. If that's the case, then it could be a faulty door switch causing it not to program. I had the doors open while doing the programming. I will try on a different car tomorrow.
    Never finishes any verified
    Wake Forest, NC
    Yeah I followed the instructions from the 3s wiki.
    here are the pics of the one I have including the inside. if anyone has an OEM one can you compare them and LMK.
    Check it out on Youtube!!
    Chrome ECU
    Hybrid 13g's
    EVO 560cc Injectors
    Spec Stage 3 clutch
    CX Racing Dual Core FMIC
    Megan SS Exhaust
    3rd Gen Lifters
    Maximal High flow converter
    Walbro FP & FuelLab FPR
    All -6an Lines
    AWS/ABS/Cruise Delete
    MP Rear Control Arms
    SS Brake Lines
    99 Front Conversion
    2nd gen Rear Bumper
    99 Combat Wing
    Complete interior LED Swap
    Skillard Fuel channel
    Oohnoo FPR Bracket
    More to Come......
    JNS Engineering verified
    San Jose, CA
    That's stock all the way.
    Wake Forest, NC
    Thats what I figured also.... So we know the FOB is stock and it is the correct one for the controller, so any Ideas?!?!?
    Dayton, Ohio
    The "door" thing got us once.
    Do your lights go on and off with opening/closing the door?
    Bob.
    Stock 18" 6 Spoke Chromies
    Indiglo Gauges
  7. #17
    Wake Forest, NC
    You referring to the dome/door lights? Yeah then come on and dim as they should.
  8. #18
    so does anyone have a source of confirmed functional remotes? I have the rear panels off and would like to get a remote setup while I have it all out.
  9. #19
    I bought one from the same place you did worked great here followed the same procedure, I had to do it a couple of times to get the sequence right. but works great now.
  10. #20
    received my remote from ebay today and I also can't get it to work. very annoyed
  • History
  • Information
  • Groups
  • Events
  • Resources
