Results 1 to 10 of 25
Thread: Stock Keyless entry troubleshooting
    Never finishes any verified
    Wake Forest, NC
    I finally got my hands on a good replacement key FOB but I am unable to get it to function properly.
    The key FOB I got is FCC ID: E4EG8DA and the controller in the car is FCC ID: E4EG8DB Part # MB920442 so they are the correct FOB/Controller.
    I set the switch to Set 1 or 2 hold down one of the buttons. Set it back to Fix and nothing happens..... The battery in the FOB is good and it lights up when a button is pressed. I pulled the controller and replaced it with another unit same model/FCC and still nothing.
    Any ideas as to what I should check?
    I really want to get the stock system working properly as I hate not having a key FOB.
    Check it out on Youtube!!
    Chrome ECU
    Hybrid 13g's
    EVO 560cc Injectors
    Spec Stage 3 clutch
    CX Racing Dual Core FMIC
    Megan SS Exhaust
    3rd Gen Lifters
    Maximal High flow converter
    Walbro FP & FuelLab FPR
    All -6an Lines
    AWS/ABS/Cruise Delete
    MP Rear Control Arms
    SS Brake Lines
    99 Front Conversion
    2nd gen Rear Bumper
    99 Combat Wing
    Complete interior LED Swap
    Skillard Fuel channel
    Oohnoo FPR Bracket
    More to Come......
    I just had this same problem this morning with a customer car. He ran out of time before I could fix it. I tried all of the same steps. Remote is brand new from Ebay. I felt like a retard not being able to get this to work haha.
    Wake Forest, NC
    Yeah mine is also brand new from Ebay. Stupid controller has no means of telling you if something is not right or if it even works to begin with!!!
    We could have gotten hosed on Ebay together!!!! SOB!!!!
    Wake Forest, NC
    Here is who I got mine from: eBay My World - remotez4less
    It is brand new. No wear at all!! Even the writing on the back is brand new. No fading on the buttons Etc!!!
    Yea, I got mine brand new from eBay My World - yourkeylessremote
    never been used, but shit don't work!!!
    Wake Forest, NC
    Same with me, But I don't know if it's the remote or wiring issue... You have other cars you can test your remote on correct??
    Was the door closed? Won't work if the door is open.
    Wake Forest, NC
    Yep door was closed.
    From Dave Black's site
    Behind the rear panel you should see a box in front of the rear speaker - this is the receiver unit
    Remove the receiver from the car body
    Find the switch labeled SET 1 - FIX - SET 2 and move the switch to either SET position. (the two SET positions are in case you have two transmitters with different codes)
    Press any button on the remote transmitter
    Move the switch back to the FIX position
    Test the new remote transmitter
    Reconnect everything making sure that the antenna connector is tightly connected to the receiver
