Page 1 of 6 123 ... LastLast
Results 1 to 10 of 55
Thread: Plastidip
    Plastidip
    It's some cool shit! Spray it on about 5-6 coats, peal it off from areas you don't want it. If you screw up, peal it all off and do again. Its that easy. Think of it like a sprayable rubber. Kinda like Rino-liner only with a softer consistency and smoother texture.
    Like every 3/S out there, the black trim on my car has started showing its age. Most people just paint over it to match the whole car when they get their cars painted. Seen a couple people mask off and respray it with krylon or some other paint and that works too.
    The thing with paint though is the "oops" factor. If you make a mistake its perminant. So if your masking lines aren't just right, you can't fix it. It's also 55 deg outside here and there's no way paint will cure as smoothly. Its every bit as durable as paint and if you don't leave any edges it won't peal off till you want it to. It's also much much much easier to work with than paint. Goes on evenly and the color is always uniform.
    This stuff was originally designed to coat tool handles but over the last year people have started spraying their whole cars with it to protect the paint and change the look of their cars. It gives a matte finish. I plan on doing a whole car in matte white soon.
    I just chose the original matte black for this experiment. Costed about $8 for one can and there's still quite a bit left over. Got it from Lowes.
    They say you don't need to mask off the car but I went ahead and masked the areas that would be difficult to clean. Figured itd be easier/faster to lay down some tape than scrub the splatter off.
    Laying out the dip.
    It does have a bit of texture to it though. Was thinking maybe I didn't shake the can enough or its the cool temps effecting the cure.
    Did the wipers inside and they turned out smoothly.
    Done!
    For doing a whole car I'm gonna be buying an electric spray gun along with 4 gallons of white dip. It'll be a full paint job including door jams, engine bay and all the hidden areas. Gonna be an interesting project.
    The headlights on the 98 started to yellow over the summer. Figured I'd try the matte white on one to see how I liked it before sanding and buffing it.
    Put on about 8 light coats. Figured out the issue with the texture was caused from not shaking the can well enough. The dip and the thinner begin to separate within minutes so its important to keep the mixture diluted as much as possible to avoid splatter.
    Note: I didn't mask off the rubber trim and just sprayed over it. It pealed right off really easily because I put it on nice and thick.
    I wasn't happy with the projector cutouts nor the look of the matte white against the pearl white hood so I just pealed it off.
    Absolutely no damage to the clear coat.
    Decided to not give it another attempt and just sanded the headlight. The yellow wasn't permiated that badly so it came out with little work. Started with 800 grit sandpaper and worked up to 2000. I'll be polishing it with compound tonight. This is actually left over compound from the mothers headlight restoration kit that I used last year on the 99 headlights.
    I am doing it in red.
    Here are some before afters. So far all I've done is my faded spoiler and mirrors. They came out awesome.
    Before
    After
    Before
    After
    The red isn't bad! Was looking at pictures of a supra that did his car.
    Canaan NH
    Looks good Greg, I especially like the wiper arms. But please dont start doing this on whole cars, or body parts...........Keyan.
    The car I'm looking at doing needs a paint job. Even a half assed paint job is worth more than the cost of this car...
    Canaan NH
    Oh, thought you were thinking of doing the VR4 matte white, I cringed.
    Have the NEED 4 SPEED.. verified
    North Texas
    Thinking about going FLAT BLACK on my car as well here ...
    3s Less Forever hate to say it...not going to get sucked in again..
    Hell no. Love the pearl white.
    Considered doing a plastidip "bra" on the car with the clear and some pearlizer over it, but it doesn't look that good in pictures.
    Got a bunch of scrap test plates at work and was thinking about stealing them to do various tests with adding automotive pearls and metallics to the clear just to see what it'll look like.
