It's some cool shit! Spray it on about 5-6 coats, peal it off from areas you don't want it. If you screw up, peal it all off and do again. Its that easy. Think of it like a sprayable rubber. Kinda like Rino-liner only with a softer consistency and smoother texture.
Like every 3/S out there, the black trim on my car has started showing its age. Most people just paint over it to match the whole car when they get their cars painted. Seen a couple people mask off and respray it with krylon or some other paint and that works too.
The thing with paint though is the "oops" factor. If you make a mistake its perminant. So if your masking lines aren't just right, you can't fix it. It's also 55 deg outside here and there's no way paint will cure as smoothly. Its every bit as durable as paint and if you don't leave any edges it won't peal off till you want it to. It's also much much much easier to work with than paint. Goes on evenly and the color is always uniform.
This stuff was originally designed to coat tool handles but over the last year people have started spraying their whole cars with it to protect the paint and change the look of their cars. It gives a matte finish. I plan on doing a whole car in matte white soon.
