Page 314 of 892 FirstFirst ... 214264304312313314315316324364414814 ... LastLast
Results 3,131 to 3,140 of 8916
  1. #3131
    SoSoCal verified
    I have maximal solids, its the mount to the engine.
  2. #3132
    Hmm. Guess I will have to cut some mount away.
    Post via Tapatalk
  3. #3133
    SoSoCal verified
    Quote Originally Posted by FeaRpb View Post
    Post via Tapatalk
    Next problem the rear hole stud nut combo on the front header dont work. To close to pipe. Solution i put in a rounded bolt with a hex top. Thats the only way to fasten it
    Unless yur engine is out or unless u know a way to put in your header bolted to the turbo in all at once which i didn't see.
    Fyi
  4. #3134
    My engine is out luckily
    Post via Tapatalk
  5. #3135
    I swear someone that got the rear fit it up, and said the only issue was the stock oil return line. Hmmm, I am disappointed to say the least.
    Mark did you post on the other site, or call him?
  6. #3136
    Apr 2011
    Mid-April 2011.
    Monroe WI
    Drove it to Monroe WI... Softend the coils for GF and 2 year old.... Also go it washed for the first time since i moved.
  7. #3137
    SKADOOSH!!! verified
    Prince George
    Turbos in place!!
    Photobucket
  8. #3138
    Holy shit!
    That's how they will be under the hood / in the engine bay?
  10. #3140
    Banned J. Fast's Avatar
    - O - SIX -
    Colorado, USA
    Quote Originally Posted by DuTTch View Post
    Its hard to take pics aying half ass bent over in the rear engine bay lol. Just cant make that angle to get it over the studs . there is a reason the stock manifold is curved. am gonna give it one more shot but dont have much hope. I really dont want to start grinding down the rear motormount. The rear stock manifold flows equally as good as the gtech one I am pretty sure plus the stock one will seal better with the heat o ring. I tried! DoI get a trophy now for participating?
    Pull the mount and install the manifold otherwise your going to be required to grind down the motor mount. It fits, direct bolt on with motor mount removed and reinstalled. You're lazy. Every aftermarket manifold kit on the market requires the rear motor mount to be ground down to install if you don't remove it... 3sx, IPS, DR, all of them.
  11. The Following User Says Thank You to J. Fast For This Useful Post:
