Got home finally, 6040 miles since Jun 15, Six Thousand and Forty Miles.
Like a Boss
Like a Boss
I finished doing some wiring and also got my wideband hooked up to the LCD boost controller. It says my tune is lean WOT and evoscan confirms I max the 550 injectors at 14 psi and 5900 rpms on GT-368s.So I ordered some Deatschwerks 1000cc injectors and NGK non-projected coppers. Ethanol here I come!
I decided why not. Lol.
Considering how it's wrapped, it looks to be an Oohnoo dual core IC setup.....![]()
They are stainless steal covered in pink bubble wrap. haha
Here is the to do list for what will be captured (in no particular order).
Update ECU Flash and Evoscan files
Cleanly install BlackStealth LCD Boost Controller
Install DC FMIC
Paint Calipers, upgrade pads, flush brake system
370Z front rotors and Jester Caliper Adapter plates (need to buy)
Install Evo 560 injectors
Install Aeromotive fuel pump
Install RB 13T turbos
Install Montaro MAF
Dejon turbo pre pipes, Y pipe
Power coat piping, plenum and valve covers
New tires (still need to buy)
Install Pampena 6spd bell housing brace
Install K&N FIPK
Upgrade FPR and if I want to do a hotwire
Drop in PRM/Carbing 3 point strut bar
Install OEM chin spoiler and splash guards
Leather Seats.com new seat covers (still need to buy, may wait until Christmas)
Straiten up some body lines on the car - the drivers side headlight and front fender do not sit right, the hood sits a little off as well.
New exhaust gaskets, she stinks a little
install Koyo radiator
Fix water filled turn signal and broken headlight
Dyno Tune for 400+ WHP on 93 pump
yeah, I noticed that to when I looked at the pictures, the door frame is filthy!
Hope to have a neat 5 minute video at the end, with time lapse, dyno video etc.
Good eye.
Yesterday, we drove to Chattanooga to pick up some new wheels for the 99, then came home and installed them. Other than the heat, it was a good day.
