We've already determined that. One of my fans is OEM. Most can't fit the bigger OEM fan anyways with a td05 setup.
We are now trying to figure out if one radiator really is better than the other, or if they are both about the same. If they are both about the same, then we can come to the conclusion that for any TD05 setup that can't run two a/c fans with a thicker radiator, then its better to have the OEM radiator.
Over in the southeast, it may not quite get up to 115*, but it gets over 100* ambient and over 115* off the road along with way more humidity than Arizona gets. Humidity does affect the cooling ability. Deleware probably experiences this occasionally, but not with as much consistency.
Humidity does not effect cooling much in a system like a car cooling system. Now, evaporative cooling is effected greatly. Also I can tell you don't know about Arizonas monsoon season, 115* and rain. I've been all over America, and the desert southwest is the hottest place, by far I've ever been.
Well what cooling system works there then? I've lapped VIR at 475 wheel(30 minutee sessions) in my old car on a 90* day and around 220* was as hot as it got. Stock hood, stock rad/fans.
I built a td05 car that cooled better with stock rad and two a/c fans compared to a 2" koyo with the same fans....so I don't know what to say...
Jason
sure if you are running a 1G ecu you can't control the fans with it, but I was talking about a flash ecu.
What you most likely have is a 2nd gen radiator setup that doesn't have the thermo switches for the fans in it because they were originally controlled by the ecu. Now you have a 1G ecu that originally didn't control the fans, so there is nothing to control them.
A 2nd gen ecu controls the fans itself instead of through the thermal switches. Luckily it is one of the tables you can edit in the flashed ecu and that was my whole point.
