Page 7 of 9 FirstFirst ... 56789 LastLast
Results 61 to 70 of 89
Thread: Copper or Aluminum Core Radiators
  1. #61
    Ann Arbor, MI
    Do they have the same amount of rows? Can you say how many 180 bends are in each gen atleast?
    Not sure what your question is here. But the radiators had the same core size over the years.
    Whuich generation has the most efficient core? 1st gen? It's heavier. Did mitsu change the design because it was too expensive to mfr?
    Looks like the first gen had the highest heat transfer at any condition. My company likely increased the fin pitch in order to save material and make a profit on the radiator. Copper prices started going up around that time.
    Perhaps this was offset with stronger fans. But I haven't verified that. An increase in fin pitch on the radiator will result in better AC performance due to increased airflow.
    My research also shows that the radiator core material changed from copper to aluminum in 1997, so likely '98 model year and up saw this change. This would result in lower heat transfer but an overall cheaper radiator.
  2. #62
    Banned J. Fast's Avatar
    I would say its unfair bias in saying OEM > Aluminum and vice-versa. There's so many styles and design considerations and variables in each core. You could amost argue they're all unique like snowflakes. Not only are there like 3 different styles of OEM cores with different copper and fin designs, the same rings true for aluminum cores. The other huge consideration is the dilution of the fluid.
    My decision in selecting an aluminum over the copper was based on several things, first being larger heat transfer area. Second, weight. Third, tube and fin design. Last, rapid outer skin heat dissapation seeing as my radiator is 2" closer to 1400 degree manifolds and dp's.
    Oem core guys, some of the bias bing spoken is from stock mounted turbos is it not? What generaion of OEM cores were you guys using and how do you know what generation you used? There' obviously enough division to say run what's working on a case by case basis, right?
  3. The Following User Says Thank You to J. Fast For This Useful Post:
    IPD
  4. #63
    Ann Arbor, MI
    You would be amazed at how much an optimized fin design can increase heat rejection. Most newer radiators incorporate a micro louver design versus the older flat fin shape.
    At any rate, increasing airflow with either a) better performing fans or b) fan shrouding will yield the best bang for your buck as far as cooling performance. Assuming your radiator core is in good shape with intact fins.
    Upgrading to a large core radiator while downsizing your fans is counterproductive. Full performance testing would have to be done to determine to what extent. Unfortunately the aftermarket does not perform this type of testing.
  5. #64
    wheatfield, IN
    this came in the mail today
    Radiator Made From High Quality All Aluminum For Maximum Cooling Efficiency.
    Radiaotr Is 2 Row Design To Maximize Cooling That Will Improve Cooling By 30-35% over Stock.
    Inlet And Outlet:1 5/16" It Would Be Large Than OEM So You Need Upgrade Your Hoses.
    Radiator Overall Size: 29 1/8"x17 6/8"x2 3/8".
    Radiator Core Size: 27.5"x14.5"x2 2/8".
    Radiator Cap Included.
    Durable And powerful Motor For Long Life And Performance.
    Fan Shroud.
    Made Of High Quality Light Weight Alumnium.
    Radiator Fan Shroud Are Direct Bolt-On.
    Thickness: 3 1/8".
    1100 CFM/2200 RPM.
    12V/80W.
  6. #65
    Quote Originally Posted by Alex3000gt View Post
    Ahh, makes a lot of sense now actually. I remember several years back when oohnoo and several other respected members of the community started an overheating discussion on the other board. I never read one single issue with the first gen's overheating but then you hear about problems with 3rd gens which was a much more modern design. I always thought the 96 and up gen's were unfortunately molested. All the good stuff was yanked out of all of them due to increased manufacturing cost. They never got the active aero, no high speed suspension, a sub par and less efficient radiator, tunable exhaust on several models. Must have been a sign of the times. It actually makes sense now, why mitsu for one changed their body styles in 96+. I bet one of their redesign considerations was to accomodate a less efficient radiator and they knew it!
    All these years I never knew there was a switch from copper to aluminum. I also never knew there were two different copper cored designs. Did everyone else, this is the first I heard of it?
    Alex, how do owners know if they have the good oem radiator other than year of MFR? Do we have to weigh them or is there a different stamp? I would assume the new oem replacement is the less efficient aluminum core built for the later gens correct? The first gen cores are no longer avail unless found used?
  7. #66
    Known as SLGuy
    Owens Cross Roads, AL
    I did not know this either. Excellent question! I was thinking the same thing on which core do you get if you were to order a new OEM radiator.
  8. #67
    Illustrate for me if you will the difference in the OEM cores and this new micro louver design. It the mico design superior? What's the design principal and intent and makes it better?
  9. #68
    let's not forget that people are also comparing radiators of different ages. an OEM radiator that's eaten 300,000 bugs, dirt, gravel, etc--is probably not going to be as efficient as a new one....much less most aftermarket designs. if you've had some plugs put in, effectiveness goes down as well.
    for what it's worth though, we can have the same discussion on fin density and cooling efficacy about FMIC cores--but people don't usually have as tangible a method for checking that...since usually the prime indicator is boosting lower than anticipated (without knock).
  10. #69
    the outernal fin density on my oem 96 radiator is 15fpi
    the outernal fin density on my koyo is the very same 15fpi
    oem 96 radiator core is ~1.05 " thick
    koyo radiator core is ~2.1" thick
    oem 96 tube thickness ~~1.5mm
    koyo tube thickness ~~2.0mm
    both are made of aluminium
    /too lazy to measure the rest but I know the koyo works much better for me
  11. #70
    Ann Arbor, MI
    You would know by the DENSO part number stamped on top of the radiator, flat piece of the tank near the driver's side radiator mount. The part number should read 422130-718X
    If the X is a 0 you have the 3.0 fin pitch copper radiator
    If the X is a 1 you have a 3.5 fin pitch copper radiator
    If the X is a 2 it is aluminum.
    Also, if your build date is before July 1994 you have a 3.0 fin pitch copper core. If your build date is after October 1997 you have an aluminum radiator.
  12. The Following 3 Users Say Thank You to Alex3000gt For This Useful Post:
