Page 4 of 9 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 89
Thread: Copper or Aluminum Core Radiators
  1. #31
    Northern Virginia
    As far as my case went with cooling; the Denso copper core stock radiator can keep the car running at operating temps 190-205 usually where as the Koyo 2in aluminum radiator, could not maintain temps. I would flip the AC on and temps would steadily climb if idling. I kept messing with shrouding, switching fans out, until I finally just called Dynamic Racing and talked to Matt, to see what setup worked for cooling on his particular TD05 kit he sells. So in my case it turned out that the stock copper core radiator worked whereas the aluminum radiators did not.
  2. #32
    Quote Originally Posted by Patryn View Post
    but is that a material difference or a design difference? regardless of case thickness, if the copper core had more surface area for heat transfer, it will function better.
  3. #33
    The stock radiator is good, but for whatever reason I overheated with it when the ac was in.
    The 3sx single pass solved my problem.
    Fyi, with the chromed ecu you can easily lower the fan on temp without adding any aftermarket crap.
  4. #34
    wire it to always be on. the only time it will bother you is if the engine isn't running with the car in accessory. that said, it also works great to replace the turbo timer.
  5. #35
    no thanks. The car will get to operating temp faster with it setup properly to come on at 180.
  6. #36
    is that really important? a few quick pedal-mashing warmups will get the temp up there anyways.
  7. #37
    Wtf? You dont run a car hard when its cold.
    Why not set it up right, it isnt hard.
  8. #38
    won't work on my setup...for one.
  9. #39
    Known as SLGuy
    Owens Cross Roads, AL
    Interesting discussion here as one person is having better luck with the stock radiator and one person is having better luck with the 3SX radiator.
  10. #40
    I've never not run an OEM radiator and ive never had a temp problem. Todds car with a 3.5" thick FMIC, a/c and stock hood, stock everything(the DR750 car) has zero temp problems with a 20 year old used stock rad.
    Jason
    I'm willing to bet it wasnt 115* either. In the desert the ambient air temp 1-2 ft off the road is usually closer to 130*. I've seen setups that could be beat on all day back east with the ac on, and 85* out pop the rad cap driving to the store in Arizona.
