As far as my case went with cooling; the Denso copper core stock radiator can keep the car running at operating temps 190-205 usually where as the Koyo 2in aluminum radiator, could not maintain temps. I would flip the AC on and temps would steadily climb if idling. I kept messing with shrouding, switching fans out, until I finally just called Dynamic Racing and talked to Matt, to see what setup worked for cooling on his particular TD05 kit he sells. So in my case it turned out that the stock copper core radiator worked whereas the aluminum radiators did not.
