Did know it was a pain in the ass. Are there any tips to lighten the work load, or no. Stealth316 is the instruction I'm going by.
Im pretty sure I just removed the heat shield and used a wrench from the bottom until it was loose enough to turn by hand? Soaked in PB Blaster for 2 nights.
Autozone/advanced rent o2 sensor crows foot wrenches. I believe this is what I use on the front.
2013 January Car of the Month - All 3s
2011 November Car of the Month - Interior
If my links/photos don't work replace penguinhosting.net/~bigmac with primaryboost.com
Uncut 3000GT keys for sale! Various colors!
Instead of needing to get a huge socket in there, its more like getting a wrench in with a ratchet attatched. Youll see when you dig in.
Well, since your o2 sensor has a wire sticking out you can't use a box wrench. This thing goes almost all the way around so the o2 sensor won't strip. Then you can wrench on tha bitch as hard as you wantAlso it allows you to use a normal racket where you can put on a long extension. I have never used penetrant with this.
Subscribing this for the future
I use the same crow's foot, works good. Also, I don't remember which O2 it was but one of them I took out with just an open end wrench, I think angle of attack was top of the engine bay (front?).
. 1992 VR4 - Java Black Pearl paint (2004 STI) with combo '92/'96/'99 custom front end .. Fittipaldi Force or 5Zigen FNO1-RC wheels . Cianci rear strut bar . K&N intake . DNP pre-turbo hard pipes . DNP hard intercooler pipe kit . Greddy Type RS BOV (recirc) . HKS EVC Black Limited boost controller . Vacuum reduction with all silicone pluming . EGR block off plates . Hot wired fuel pump . AEM AFPR @the rail with Robbeck adapter . Fuel rail loop . Tanabe knockoff down pipe . No cats . Single Turbo Flamer full 3" cat back . RPS Max pressure plate with street disk . Seattle92VR4 solid motor mounts . '99 Lifters . R1 Concepts slotted rotors . Supercar Engineering brake caliper stiffening bolts . HHH data logging . Red Line fluids .
