Results 1 to 10 of 21
Thread: Front 02 sensor change
    Maryville, TN
    Did know it was a pain in the ass. Are there any tips to lighten the work load, or no. Stealth316 is the instruction I'm going by.
    Im pretty sure I just removed the heat shield and used a wrench from the bottom until it was loose enough to turn by hand? Soaked in PB Blaster for 2 nights.
    Autozone/advanced rent o2 sensor crows foot wrenches. I believe this is what I use on the front.
    Maryville, TN
    How does that help? I've never had to change one out in 21 yrs.
    Instead of needing to get a huge socket in there, its more like getting a wrench in with a ratchet attatched. Youll see when you dig in.
    Well, since your o2 sensor has a wire sticking out you can't use a box wrench. This thing goes almost all the way around so the o2 sensor won't strip. Then you can wrench on tha bitch as hard as you want Also it allows you to use a normal racket where you can put on a long extension. I have never used penetrant with this.
    Maryville, TN
    Quote Originally Posted by Sean Johnson View Post
    Sounds like a plan guys. Heading to Advanced Auto tomorrow morning. I get it now.
    JNS Engineering verified
    San Jose, CA
    Subscribing this for the future
    2004/5?
    SW Connecticut
    I use the same crow's foot, works good. Also, I don't remember which O2 it was but one of them I took out with just an open end wrench, I think angle of attack was top of the engine bay (front?).
    Maryville, TN
    Quote Originally Posted by Rom3BreaK View Post
    The one I'm attacking is the front drivers 02 next to the alternator
