Results 1 to 10 of 17
Thread: timing issues
    Jan 2011
    az
    timing issues
    what could cause my timing to keep skipping teeth? failing tensioner, cam gear or what?
    Did you use an OEM tensioner?
    Jan 2011
    az
    i have never replaced the tensioner since ive owned her. should i replace?
    Sounds like it. When was the last 60k service done?
    Jan 2011
    az
    well a few years ago, she popped and everything was replaced besides the tensioner i think.
    At the very least, replace the tensioner with OEM. My question however, how are you not damaging valves during all of this?
    Jan 2011
    az
    good question. idk. dude i just bent the valves a couple of months ago lol and im not trying to go through that process again.
    San Francisco, CA
    My guess is a combination of:
    1) being cheap/lazy and not replacing critical components when you "fix" it
    2) your procedure for setting the timing is wrong
    AEM s2 EMS | E316Gs | E85
    Jan 2011
    az
    Quote Originally Posted by Intropy View Post
    if it is something i cant mechanically do myself, i will not attempt. i stated when it blew up 2 years ago, the guys who built the engine replaced everything besides the tensioner. about a week ago, the car did the same thing so he went in and reset the timing. in the process, he took the tensioner out and it looked old as fuck. i dont know why they didnt replace that as well as it is a critical component.
    San Francisco, CA
    Quote Originally Posted by keo92stealth View Post
    With a car this old / esoteric you've got to own this stuff. Don't just let your mechanic do whatever he wants, TELL him what to do. Make darn sure he knows how to properly set the timing. Any mistakes will probably cost you the engine or worse.
