what could cause my timing to keep skipping teeth? failing tensioner, cam gear or what?
Did you use an OEM tensioner?
i have never replaced the tensioner since ive owned her. should i replace?
Sounds like it. When was the last 60k service done?
well a few years ago, she popped and everything was replaced besides the tensioner i think.
At the very least, replace the tensioner with OEM. My question however, how are you not damaging valves during all of this?
My guess is a combination of:
1) being cheap/lazy and not replacing critical components when you "fix" it
2) your procedure for setting the timing is wrong
AEM s2 EMS | E316Gs | E85
if it is something i cant mechanically do myself, i will not attempt. i stated when it blew up 2 years ago, the guys who built the engine replaced everything besides the tensioner. about a week ago, the car did the same thing so he went in and reset the timing. in the process, he took the tensioner out and it looked old as fuck. i dont know why they didnt replace that as well as it is a critical component.
