The walbros bulbous end is about the same size as the denso, im using a modified stock hangar with bulkhead fittings and a worm clamp, nothing special, you just need to lower one pump in first, then the rest of the assembly, then pull thr pump up and tighten it on the AN fitting and crank the worm clamp tight enough to move the pumps far enough away from the floater arm. And then drop in the half lowered assembly and your done! Tricky, but not impossible with a lil patience, it fit a lot easier than i thought it was going to
[3SX Test-Pipe to Flow-master Delta 40 Series Custom Exhaust// 99' Lifters // Cold-Air Intake // MB Wheels 5X]
going to go look at some recaros from an evo 8 today...
93 dodge stealth r/t tt, 457awhp and 424awtq on 93 pump
13t turbos, 550cc injectors + afpr + walbro, maft + z06 maf + safc, intake + fmic + exhaust,
lightweight flywheel + crank pulley, jackhammer timing gears, pampena short block, 93 pump
94 dodge stealth r/t na, used to drive: 13.9@100
60 shot of n2o, 360cc injectors, safc + tt fuel pump, intake + exhaust, lightweight flywheel + crank pulley, 93 pump
93 dodge stealth r/t tt: personal parts car
03 ford focus se: beater
Tuning today.
