how much did the manifolds cost ya, or did you make them yourself?
twin 35r's should be fun as hell.
I'm in tx, heading into summer, n fkn a/c went out.
Sent from my Nexus S 4G using Tapatalk 2
I installed the shifter bushings and shifter base washers, and then decided to make a "How To" post as well.
Finally scrubbed my engine bay and cleaned it up a bit.. It was starting to look black lol
1993 3000GT SL
Mods: 95 front end, Robomodded Glass Headlights, VIS CF hood, Megan Racing Coilovers, relocated battery, short ram intake, VR4 Plenum, OBX LSD, OBX longtube headers, test pipe, 3SX underdrive crank pulley, Fidanza 9lb flywheel, Spec stage 3 clutch, solid lower engine mounts, 80a poly filled upper/trans mount, poly front sway bar bushings, Momo steering wheel, 3rd gen lifters, Konig 18" wheels, 4300k HIDs, gutted trunk, AC delete, PS delete, Cruise Control delete, ABS delete, SRS delete.. Plus other random stuff.
Update:
Pulled transmission tonight, found a Napa special clutch (LUK). Looks like flywheel step was off (to high) and the clutch was slipping. Shame as it is fairly new looking....looks like it will be part of a scrap run now.
Also picked up a HKS BOV (Thanks John) to replace the leaking EVO VIII BOV. Haven't tested it, but if it holds more than 19psi I am golden as that is when the current BOV started to leak. Figure that plus clutch means I can maybe get 24spike out of the 9b's and maybe 17 to redline? We'll see after break-in.
I fixed the solenoid and i got the car running, and it run like a champ![]()
3SNG15 Best overall
Runs 12's (12.98's!!!!!!)
My Garage
