Jump the connector on the rheostat to give full power to the stock lights and then wire the rheostat itself up to +12v to control the Stack`s?.
If you`re happy with the normal gauges on full brightness you can just unplug and jumper the connector, you then have the rheostat free to wire up as you wish to use with the Stack`s (convert it to +ve feed).
hmm I'd have to check exactly how I have my greddy gauges setup, but I'm using the stock rheostat just fine.
