The instructions say "+12v Dash Lighting" I'm thinking you maybe right and I'll tie it into the rehostat. But even still, hooking it up to another power source would either dim it to a preset dim (or fully off) or not dim it at all (since there would be no resistance on power). I'm not too worried about it, I'll play around with it later.
Ah, ok, so it sounds like using the rhesostat will work. Sweet. I just wonder how dim they'll get compared to the EL. Looking nice :367023_u68:
R135 ╚╬╬╝ - 24
Alright so I'm not great at wiring, can someone help me with figuring out how to wire up the dimmer light? I did some testing and there is a white +12v wire that can be used to dim the lights on the gauges (if the correct mode is set on the gauge). In this mode the lights are proportional to the voltage on the white wire (no voltage no light). The stock gauges use a rheostat ground wire to dim them (I need a positive wire). Also with the headlights off (aka daytime), I'd like the lights to be on full power. Guessing I'll need a relay to trigger the white wire's power source between a normal "full power" wire and one controlled by the rheostat. Can anyone help me out here? Small words please lol, I'm terrible at wiring.
Dimmer is not going to be possible with the stock lighting! The stock dimmer rheostat controls dimming on the negative side not the positive side! I just installed Prosport gauges in my dash about a week ago and ran into the same issue. Looked over the stock wiring and found out that the rheostat dims on the negative side..... There is nothing on the stock wiring that will let you dim using the stock dimer. You would have to build a new dimmer switch/rheostat to control the new gauges!
Check it out on Youtube!! 93 Stealth TT - The Stealth Project Renegade Tech Works ECS Controller on Intrax Springs Chrome ECU Hybrid 13g's EVO 560cc Injectors Spec Stage 3 clutch Ninja Performance Output shaft & Input spool Ninja Performance Solid Tensioner & Gates racing T-Belt CX Racing Dual Core FMIC Megan SS Exhaust Fidanza Cam Gears and Clear Covers 3rd Gen Lifters HKS BOV K&N FIPK Maximal High flow converter Walbro FP & FuelLab FPR Maximal and Seattle Solid Mounts All -6an Lines Custom -6AN coolant neck lines AWS/ABS/Cruise Delete MP Rear Control Arms SS Brake Lines 99 Front Conversion 2nd gen Rear Bumper 99 Combat Wing Complete interior LED Swap Skillard Fuel channel Oohnoo FPR Bracket . . More to Come......
SPDT Relay: 86 and 85 would be spliced into a 12V line that has power only when the headlights are on (No, I don't know what to use, maybe directly in the 12V feed to the headlights? If you do that, make damn sure the relay can handle the load) and 87a would be a 12V feed, 87 would be the after rheostat feed. 30 goes to the gauge. edit: wait? The rheostat dims the negative side? That's... uh. well it makes sense, that's all I can say, lol
Hmm, I'm going to have to do some digging. There's got to be a way to convert the resistance on the rheostat's negative output into a + signal.
There is, but I'm on my phone now and can't find any easy way to explain it. If you don't find anything, I'll try to post something up tomorrow.
Yeah that would be great thanks
So, I had my dad who does this for a living look it over. Yep, since Mitsu did the gauge wiring backwards, this is going to be a real bitch, lol. He said he'll draw up a wiring diagram that will work. edit: Obviously just adding your own rheostat will work as well, and will be infinitely less sucky in the long run.
After thinking it over I am just going to install a potentiometer to dim the lights, and a relay so that the gauges are dimmed at night (using power from potentiometer) and during the day they are on full power. I realized I like to have all the other lights the rheostat controls fully lit, but the stack gauges are just way to bright at night to be fully lit, so a separate control just makes more sense. Thanks for the help though guys!
Forum Rules
