View Poll Results: What hp power bracket does your car fall under
Voters
63. You may not vote on this poll
  • Stock
    19 30.16%
  • 300-399
    15 23.81%
  • 400-499
    13 20.63%
  • 500-599
    6 9.52%
  • 600+
    10 15.87%
Page 1 of 6 123 ... LastLast
Results 1 to 10 of 59
Thread: What Horsepower bracket does your 3/S fall under?
    Pueblo, CO
    Thumbs up What Horsepower bracket does your 3/S fall under?
    Lets see who is in the different power brackets. Should be cool to see who has what in our community. If you have links to dyno runs or sheets, post em up!
    Copy and paste this format so Its easy to read:
    Year: 1991
    Model: 3000gt vr4
    Hp: 551whp
    Fuel: E85
    Year: 1992
    Model: 3000gt vr4
    Hp: 418whp
    Fuel: straight pump, no meth
    EDIT: i made 100whp/200wtq @ 2200rpm
    180whp/340wtq @ 3000rpm
    220whp/400wtq @ 3200rpm
    300whp/400wtq @ 4000rpm
    400whp/350wtq @ 6000rpm
    upgrading the exhaust might help, or at-least getting an aftermarket dp. i might get a dp and meth setup this summer. but because of the 8.5:1 pistons i cant run quite as much boost as i used to (16psi now vs 18psi) but i make good low end tq so im happy.
    the basic go fast bits...
    Tuned by Ray Pampena
    Just a fun Daily Driver.
    Year: 1999
    Model: 3000GT VR-4
    HP: 254 awhp (stock, with flash)
    Fuel: 93 pump
    Whatever stock injectors and stock ECU puts out with 13t's and FMIC @ 13-17ish psi is what I make. I refuse to dyno my car and have my dreams of having a 200HP+ car crushed.
    Year: 1994, now with 1993 engine
    Model: Stealth TT
    Hp: ?
    Fuel: 93 pump
    zero ..
    STL3S Not Verified
    Oct 2005
    Model: Stealth TT
    Hp: ?
    Fuel: 93 pump
    I bet mine has more than yours!
    | @/|/| +|2()|/| verified
    December 2009
    Fox Cities, WI
    Current or spring numbers? Ill wait till spring..
    Quote Originally Posted by whitedragon View Post
    Duhhhhhhh! It better. If it didn't, I'd have a chat with your mechanic...
    Zero ..
    Taichung, Taiwan
    Mine is basically stock. I made 287awhp@14psi with whats in my sig
    1995 3000GT VR-4 Black
    K&N Air Filter / Topline Engineering Ground Kit / Precat Eliminators / Walbro 255 / DNP Downpipe / 3SX Fuel loop / JDM EVO MR BOV / Hallman Pro RX / 3SX Single Pass Radiator / Tein S-techs / 3SX Rear Control Arms / 3SX Custom Poly Motor Mounts /
    306.5hpawhp 320.5awtq @14psi
    Sold - 1994 Mitsubishi 3000GT Pearl White Base
