Page 11 of 108 FirstFirst ... 9101112132161 ... LastLast
Results 101 to 110 of 1073
Thread: 3SGTO Biggest Loser Competition
  1. #101
    Quote Originally Posted by 93STLTH View Post
    So, starting stats are:
    5'10"
    229 lbs
    25% body fat
    47.5 in at the navel
    I don't expect to lose a lot, but I'd like to get down around 200-210. The main thing for me will be reducing that waist measurement.
    No offense but I am having a hard time beleive the BF% number. While I know its not 100% accurate my scale says I am around 22% BF being 60 lbs lighter and the same height as you. Don't have an accurate measurement at navel, but I wear a 32 waist in pants.
  2. #102
    Madison Heights, Mi
    I'nm hoping he meant 37 not 47. Hell I'm a 44 and 50lbs more
  3. #103
    Key Largo, FL
    I wear a 38 pants and it's loose on me, the measurement is at the bellybutton, which is above my pants line.
    Stealthee, I've been an iron pumper for most of my adult life, (started lifting around 1982) so that's why my BF % is relatively low for my height and weight.
    2013 NG: 1st place, FWD Drags
  4. #104
    Madison Heights, Mi
    THis would mean that yes when you put 47 inch waist in your 1st post it was an error
  5. #105
    Andover, MN
    Where else is the weight if you wear a 38 loosely? I weigh less than you and wear a 38 pant and it fits normally....
  6. #106
    If he's fairly muscular then in his muscles. Muscle does weigh more than fat.
    I'm guessing that I need to get an actual BF% test because I am basically lean and toned all over, except for a minor belly. My % may not be near as high as my scale tells me.
  7. #107
    Cazenovia, NY
    Being a bit nit-picky here, but muscle does not weight more than fat. 1 pound of muscle weighs just as much as a pound of fat. Muscle is more dense than fat, while fat takes up more volume.
  8. #108
    Its the same damn thing. If you took a 1lb chunk of muscle it would be smaller than a 1 lb chunk of fat.
  9. #109
    Cazenovia, NY
    Exactly, it's not the same thing because in that example, they weight the same yet are different volumes. I know what you and everyone means when they say that muscle weighs more than fat, it's just not a correct statement though.
  10. #110
    You're in your engineering "I'm right and everyone else is wrong" mode.
    EDIT: And to put it one more way, if you take a chunk of mucscle that weighs 1lb, and you take a chunk of fat that is identical in size to that chunk of muscle...... the fat will weight less.
