Page 5 of 8 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 80
Thread: Morgan's Motorsports Front Splitter
  1. #41
    Apr 2011
    Mid-April 2011.
    Monroe WI
    Anxious to see pictures colossus
  2. #42
    Mad JDM Tite
    STL
    Quote Originally Posted by propbreaker View Post
    I am intrested in one how well do they hold up the roads around here are pot hole riddled. or they come on and off easy?
    You wont break it unless you straight up hit something with it, and even then i bet you break whatever its attached to first.
    Jason
    Jason is pretty much on target, the main focus of the material choice was durability so these splitters will take more than their fair share of abuse and look no worse for the wear. The material is very abrasion and impact resistant, and it will maintain its shape quite well. I have personally bottomed my splitter out on pavement and even gravel without damaging it. I even dug it in deep enough in the gravel that it literally shoveled gravel over the top. I would expect the mounting bolts to bend and the Aluminum support brace to bend prior to the splitter actually breaking.
    As for ease of removal it goes on and off with 8 bolts, 4 on the corners of the bumper cover and 4 on the sub-frame. So if you need to remove it isn't tough. But it is designed such that it won't have to come off for basic maintenance and/or towing; you can still do oil changes, check and/or fill your transmission, as well as get to your front tow hooks wiht the splitter installed.
  3. #43
    Iowa
    Is there any plan for fitment on a 1g stealth? I really want to get this, but I don't want to have to get a new bumper too...
    ~RABBIT~
    1991 Dodge Stealth RT/TT - In the garage... Close to completion...
  4. #44
    Mad JDM Tite
    STL
    Quote Originally Posted by THE_FATTIE View Post
    There is a plan but it is still in the works. The 1G stealth bumper cover is significantly shorter than all the others which means it will require an application specific option.
  5. #45
    Quote Originally Posted by Blackmount View Post
    ditto. that's VERY close to what i'm planning on doing with my car; except that i'm not going to pull another "sinsvr4" and do the 1g/2g blend. F.U.G.L.Y.
  6. #46
    Delaware
    Any reason it sticks out so far on the 99 nose vs the 97/8 one?
    Jason
  7. #47
    STL3S Not Verified
    Oct 2005
    Jason
    Optical Illusion
  8. #48
    Mad JDM Tite
    STL
    Jason
    Quote Originally Posted by whitedragon View Post
    Optical Illusion
    The splitters mount via the same bolt holes on the subframe from one car to the next, so the splitters all have the same physical location relative to the frame. I would have to agree that it is an optical illusion.
  9. #49
    JNS Engineering verified
    San Jose, CA
    No clearance hole for the front crossmember jacking point. Is this an issue? Do you guys with lowered cars have a low profile jack? Mine barely fits under my lowered car without even considering the 0.5 inch splitter thickness.
  10. #50
    Jul 2011
    Chicago NW burbs
    I hear that. same here. That would be a good thing to cut out if possible even if it was just a 2" x 2" so some sort of jack could slip in to help support the front of the car. I hate putting pressure on the sides if I can avoid it
