Page 2 of 8 FirstFirst 1234 ... LastLast
Results 11 to 20 of 80
Thread: Morgan's Motorsports Front Splitter
    How much does it weigh?
    Apr 2011
    Mid-April 2011.
    Monroe WI
    Say I want to put one on my 92 SL, But I have a 99 Front end conversion, Do I order it for a 99 or do I order it for a first gen?
    Mad JDM Tite
    STL
    Quote Originally Posted by zelstin View Post
    To be honest we have not weighed one yet so we will check on that this weekend and post up the result. My expectation is that it will be heavier than the other splitter options on the market for our cars. We were more concerned about durability than weight when we selected the material.
    Quote Originally Posted by Blackmount View Post
    You don't have to specify a model year when you order it, it is a universal fit. The only bolt holes the splitter uses on the bumper cover are the ones at the rear corners just in front of the tires which are the same on all years. And then the other mounting locations are on the sub-frame which is independent of model year.
    Apr 2011
    Mid-April 2011.
    Monroe WI
    Are these ABS Plastic? Do I have to worry about my exhaust melting through at all?
    Jan 2011
    NorCal
    1Gen Stealth with 97 3KGT front end; what does it matter that the original bumper for the 1Gen Stealth is shorter than other cars if the mounting points are universal?
    STL3S president
    St. Louis MO area
    No these are HDPC and if you have a low hanging downpipe (as I do) you only need to cut the splitter to clear it and allow a 1 inch air gap around you downpipe
    Quote Originally Posted by jozRT/TT View Post
    The problem with the 1st gen stealths is not the mounting points, but instead the fact that the front bumper cover at the bottom is 2 inches higher and leaves a large gap between the splitter and the bumper cover. If your car has any other bumper cover BESIDES the 1st gen stealth bumper cover then it will bolt right up and look great. No matter what the car was originally. So a 1st gen stealth with a 97 3KGT front bumper cover will work fine.
  7. #17
    I was really hoping I'd win that one at NG this year. Any pics on a 2nd gen 3000?
    Corunna, IN
    Hell I think we all wanted to win that splitter at NG.
    '92 Stealth ES
    '95 Stealth R/T
    '93 3000GT VR4
  9. #19
    Jan 2011
    NorCal
    Quote Originally Posted by xwire View Post
    Thanks for the explanation. A few more questions:
    1) Has anyone compared this splitter to the aluminum one?
    2) Is shipping via Greyhound freight an option since it will cut down shipping costs?
    3) Are there enough people interested to get the group buy going?
    You can PM me paypal address as well. Thx.
  10. #20
    Mad JDM Tite
    STL
    So here is a breakdown on the weight:
    splitter = 27lbs
    mounting hardware = 1.5lbs
    Total = 28.5lbs
    I forgot about Greyhound as a possible shipping option, thank you for the suggestion I will check into it.
    As for a direct comparison to the Aluminum splitter, we have not had the opportunity to compare them side by side. Based on the photos I have seen the shape is similar and the parts seem to extend past the bumper cover in a comparable amount. The main differences that I am aware of is mounting style and material choice/thickness. The Aluminum splitter appears to mount primarily to the bumper cover with two bolts going into the subframe at the front jack location. This method would set the front angle of the splitter by the difference in bumper cover to subframe height. Our splitter mounts primarliy to the subframe, only attaching the bumper cover at the rear corners where it matches the subframe height. And our mounting hardware allows the user to select their desired splitter angle via the front mounting bolt spacers. I would need to see the part in person to draw any other comparisons/contrasts.
    Edit: Additional info for comparing the Morgan's Motorsports Splitter the Aluminum version
    Weight - the aluminum splitter was quoted as being 18lbs, so it is 10lbs lighter than ours
    Tow Hook Access - the Alumnium splitter requires modification to allow for tow hook access. Our splitters come with openings for the tow hooks already cut.
    So far you are the first to inquire about the group buy, so at this time we don't have enough interest. We will keep the option open though, so if you want a splitter and you are willing to wait a little to save some money we are more than happy to work with you.
    And I will check with Von on the appropriate paypal address for you.
