So i got the car out last week from winter storage and already less then one week in I have issues....so here goes.
Back story:
Last season before I put the car away after leaving the car sit all day at work and getting into after, when I pulled out onto the road, the car would hesitate then all of a sudden take off like no ones business. Once it got down the road no problems would arise. Idle was awfully high though, when stopped at lights once the car got up to temp, it would sometimes idle at 2000 RPM, but if you fully pressed onto the brake I could get it to drop down to 1500-1200 RPM range.
This spring however I continued to have the same problem, however Sunday evening and yesterday morning I came across a whole new issue. When backing out of my driveway in first gear or reverse, it felt like the car was going to stall out and engine ran very rough. Once I got into the throttle it seemed to be fine. Monday morning, on the way to work when driving downtown going about 35 it proceeded to do the same thing, running very rough them throwing the service engine soon light, after a certain throttle point it would turn the light off then operate fine, it did this three different times and speeds varying from 40 mph to 25 mph. I parked it at my parents house and borrowed her vehicle to go to work and my step father looked at it and seems to think its the TPS sensor, it did not run rough for him however but the idle was high on it. I went over today to look at it and had read that disconnecting the ECS computer sometimes fixes the issue, and I took it for a drive and had zero problems, however the idle is still high (2000 RPM at stoplights until I apply full brake pressure, then it drops down to 1200-1500)
I have read some of the troubleshooting tips and honestly I am more confused now at what to look for, TPS, IAC, ECU. I do not have a datalogger, however the car is wired up for it, but I don't have a Palm or the software.
What do you guys think?
