ok, bugs...
car 1999 VR4
Issue 1: The rear trim and rear low seem to be switched. When I go to the rear trim menu to watch live info, the low setting is moving all over the place. the rear trim setting is acting like the low should be. The front trim setting seem to work correctly. The rear low will also go as high as 199. Shouldn't the trims and low mid high only go to 150? what is the max reading for these?
www.Chromedecu.org
2 year Warranty on all ECUs.
How To Contact Me:
eMail: apape10@yahoo.com
3SI: Jesters Deadd
www.Chromedecu.org
bugs...
car 1999 VR4
Issue 2: My car will get a CEL and I try to check the trouble code and it always comes back no messages in both the active faults and stored faults. The clear all messages works fine.
I recently installed a 99 3000GT VR4 ECU into my 93 Vehicle and took it for a spin a few minutes ago. I decided to check out how the CEL codes worked and observed the same thing, the CEL would come on during the test. I'm pretty sure I know what it is already because I asked the ECU to perform a diagnostic test before pulling codes on 94-99 model cars. I'll just skip that forced diagnostic test and see what happens.
You could be right on the rear trim thing, I asked one person to give me feedback if it was working and they said it looked correct. It is very likely what you said, "Trim and Low fuel trim are mixed up". Fuel trims usually go between 80-140 I think, and the trim by itself has a much wider range.
Send me your email address in PM and I'll give you an update.
Oh i was also in the config menu and there is a coolant alarm and another setting at the end of the menu that you didn't have in your user manual. What do those two settings do?
The manual gets updated when new features get added. The coolant alarm alerts you when your engine coolant temperature exceeds this number, similar idea to knock alert. This could be useful those with large front mount intercoolers and have overheating issues, this will remind them. The "Screen Refresh" allows you to define how often the screen updates with new data. Think of it as a delay, the higher the number the less frequently it is updated. Similarly the lower the number, more often the data is refreshed with new data.
I haven't driven the 99 ECU swap very much to see an error yet, but I'm expecting to see a CEL error for it soon. I'm going to disable the second set of O2s if it's available in the ECU-flashing software. If it's not in there, I can build an O2 simulator for it.
