Results 1 to 4 of 4
Thread: MMCd has no test option
    Forum User verified Feedback Score 4 (100%) Frostedbutts's Avatar
    I'm using a Palm M125
    MMCd v1.8g
    No matter what I do I can't get access to a "test" option I'm reading about.
    In monitor/review mode with log checked, unchecked, paused, unpaused etc etc. I've checked up in the menu by tapping MMCd in the top corner where it gives me the options to save/upload and the other menu with "About" in it. Regular logging works, so it is properly connected and reading signals from the car.
    Is there something I'm missing?
    I Kill Threads verified Feedback Score 1 (100%) Goallie11's Avatar
    Wichita KS
    When you first start it and the only buttons you only see are "new" or "load" or however it is, click up top on the mmcd and go to test.
    I don't have mine on me and just figured it out the other day so the wording may not be correct, but you access it from the first menu.
    1992 3000GT VR-4
    I think ill take this opportunity to plug my write up.
    http://www.3sgto.org/f2/mmcd-guide-3773.html
    Also make sure your cable is connected to your obd1 port before you give the car any power, I have had some wierd things happen when I decided to log without shutting the car off.
    Oh okay, you select it from the beginning before you start logging. I knew it was going to be something simple D:
    Thanks!
