Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 40
Thread: mystery overheating
    you mean its cooled by the coolant radiator? so a rise in either motor or trans will cause the gauge to rise???
    i went an bought a thermal thermometer, here are the readings, please read carefully an compare
    ok before i left an the car was idling, everything is in F lol, car gauge was at normal
    front head-171
    h2o pump-174
    rad-120
    trans pan-136
    trans-157
    after being on the interstate an it overheated three times, i took the temps
    1st time it overheated car gauge red line was on the thermometer symbol
    front head-180
    h2o pump-195
    rad-180
    trans pan-149
    trans-152
    2nd time it overheated, car gauge same spot
    front head-167
    h2o pump-188
    rad-176
    trans pan 140
    trans-163
    3rd time it overheated lol, car gauge same spot
    front head-187
    h2o pump-197
    rad-180
    trans pan-150
    trans-180
    an after the highway idling in my drive way, when the gauge was almost back to normal (1-2 ticks above normal)
    front head-160
    h2o pump-180
    rad-140
    trans pan-122
    trans-160
    That,s a bad radiator. And just feel if the fans blow toward the motor or out the front. bepending on how the fans are bent if they will be clock or counter. With you fans hot wired, they shoulkd be moving a ton of air.
    Thermal Engineer- Mmbr Since:8/2005 verified
    Ann Arbor, MI
    Quote Originally Posted by GTwizard View Post
    My bet is reversed polarity. You can't really 'feel' if air is flowing one way or another, you just feel random air blowing about, haha.
    Use a sheet of paper and hold it to the fan, if it sticks - your polarity is reversed.
    '92 3000GT Base ATX converted to MTX - Parted Out
    '91 Stealth ES MTX - Fastest NA FWD at NG11 Drags - SOLD
    '91 Stealth RT/TT Check out my blog
    '10 Jetta TDI MTX - 6 speed: 50MPG Highway
    Rest In Peace, My Brother SGT. R. Evans Taylor: Apr 23 '83 - Oct 14 '11
    can i ask why you think its a bad radiator???
    i tried just feeling the air, but with both fans on it just feels like alot of air lol so thats why i said they both spin towards the drivers side,
    Ann Arbor, MI
    Quote Originally Posted by leggomieggo10 View Post
    Use a sheet of paper, hold it to the fan. If it sticks, BAD. If it blows away, GOOD.
    Report back results, I can't help you if you don't try these things.
    had the same issue in my 93 sl. Idle in the driveway temps are fine, drive it and it would overheat. Tried everything even went to a radiator shop and had it flow tested, changed the rad because nothing else was was fixing it and then it was fixed,it was just old and needed too be replaced
  7. #17
    alex, i stuck a piece of paper down by the fans an both of them pushed the paper towards the engine, so i guess thats right.
    does anyone know or sure if you put a manual trans rad in a automatic an than hook up a aftermarket trans cooler?? i dont have money for a new rad but i have a rad from a manual, i could afford a 30 dollar trans cooler. would this work the same?? in theory it should
  8. The Following User Says Thank You to leggomieggo10 For This Useful Post:
  9. #18
    Feb 2011
    NE oHIo
    your radiator can flow just fine and still be a piece of crap.
    -SP
  10. #19
    Warner Robins, GA
    Just because you don't see any fluid on the engine or ground doesn't mean you don't have a leak. Many times the coolant simply evaporates before you see it. I had a car that would never overheat except after 5 or 6 dyno pulls. A year later I find a "pin hole" leak in my Koyo radiator (right by where the AC stud would hit it). Replaced the radiator and went back for tuning after a turbo change. Did 15 pulls, no issues at all. I never saw any water on the ground. Maybe once a month, the temp gauge would start to go up and I'd have to put coolant in the engine, typically about 3 quarts. The coolant had slowly leaked out the pin hole in the radiator and the engine then pulled a small amount of air back in the hole. Eventually, enough air gets in to form an air pocket in the top of the engine and overheating starts. So, even if you don't see any leak and even if the overflow tank level never gets low, you CAN have a leak which causes overheating when the system is stressed.
    You can install the manual radiator and use an aftermarket trans cooler, but I wouldn't do that for long. Even the big trans coolers won't cool like the stock radiator tank. Just my .02.
  11. #20
    well its a na, that never goes above 3rpms. i drive it like a sissy.
    ive always heard the stock trans coolers are crap. that you should always just go with a aftermarket trans cooler.
    i have a extra coolant temp sen im gonna change out today before i do the rad swap
