I recently build couple of computers with SSD. even with low end mobo, cpu and ram, those machines fly! win7 or mac os x. I'd get SSD.
Seems like this tech still has a lot of failures. I have read a lot of complaints about it. But when it works it is great. I wonder how stable these drives are after they are rewritten a few times. It should be said that these solid state drives do nothing for improving frame rate in games. But if a game does a lot of file swaping mainly because you are short on ram and use a ram drive then a SSD can really boost game performance. But they seem to have a high failure rate. When I compare to a platter hard drive I have only had one hard drive failure ever since 1984. In fact my oldest hard drive is still running from 1984. Mostly useless as it is so small and slow but it does still work.
I have 12 hard drives only one failed to date. The one that failed is 14 years old.
Thanks again I was not aware win 7 was this backwardly compatible. An idea is forming. Maybe get a SSD drive and install win 7 on it. Make it the boot drive. Keep XP on the hard drive. If the SSD drive fails I can go back to make the hard drive with XP the boot drive and have XP running as a backup. It would be nice to have a multiple boot configuration for windows I really do not want to reinstall all the software under win 7 and repatch it all. Is it possible to do this with win 7 and xp? Some of the old games might not even work under win 7. Can I have 2 boot drives and choose which one to boot from at a prompt during startup?
If you are worried about SSD's, get an intel one. I've had mine for a couple months, and so far there has been no issues. With the wear leveling and updates to the controller/firmware that Intel has done their SSD's are great. Mine has actually increased in speed significantly since installing it. The Win7 startup screen doesn't even get through it's entire animation sequence before I'm at the login screen. I have my SSD as my OS drive and have a pair of velociraptors in raid-0 for gaming.
To be honest, I haven't done a dual boot system in so long that I doubt my knowledge for that will be worth much anymore. I do know that to install 7, you cannot do a straight upgrade to 7 but requires a fresh partition.
I have 2 intel SSD's with 0 issues. Just bought a kingston(cheap) that has huge failure rates if you don't upgrade the firmware. (haven't used it yet)
If you only need one gaming w7 machine then just put professional on it w/ xp mode for the older files and programs.
Personally there has been no software issues for me to need to use my xp mode at all.
If your worried about a drive failing then back up your info. HDD's are super cheap.
any drive can fail. this is why back up is important. I tried OCZ and Kingston SSD. both work fine for quite some time already. HUGE speed upgrade, especially over a 5400rpm laptop drive.
Those, who stand for nothing, will fall for anything.
On the Internet you can be anything you want. It's strange that so many people choose to be stupid.
only SSD failures ive had are with OCZ... Kingston, Crucials are all great for me so far since i switched.
