Hi,
I have to remove the rear valve cover due to lifters problem and before I do something wrong I need a bit of help with the removal.
I have loosened all the bolts and now the valve cover is free to move up and down but it seems that the two brackets that hold the plenum in place are an obstacle to pull it out.
In this pic that i found on the net the brackets are in their place an the valve cover is out.. maybe I missed something? How I can remove it without touch that brackets (i can't see the bolts that hold them to the block!)
