Page 15 of 892 FirstFirst ... 513141516172565115515 ... LastLast
Results 141 to 150 of 8916
  1. #141
    Banned J. Fast's Avatar
    - O - SIX -
    Colorado, USA
    Pulled the trans after work... and every minute of it it sucked!
  2. #142
    SKADOOSH!!! verified
    Prince George
    Did you drop it out the bottom or pull it from the top?
    Photobucket
  3. #143
    Riding topless!! verified
    Owned 8 3s since 2005.
    Corpus Christi
    After the trans are you fixing the holes in your hood? Did it rust thru?
  4. #144
    - O - SIX -
    Colorado, USA
    Quote Originally Posted by Gearheadvr4 View Post
    That hood definitely needs a fixin! You can't ee it in the pics but it's all spidered out. It came unlatched on the hwy. I have a replacement, it's in the loft.
    Quote Originally Posted by J_Parker View Post
    Bottom. Comes out really easy once you get all the crap out of the way. I hate droppin these trans, doin this after work kicked my ass! It's time to crash
  5. #145
    Prince George
    Lol I hear ya man, I'm in no rush to mine back in
  6. #146
    - O - SIX -
    Colorado, USA
    I'm convinced it's easier to pull the engine with the trans attached vs just pulling the trans.
  7. #147
    Prince George
    It definitely was, I dropped everything out the bottom when I took it all out.
  8. #148
    Installed an aluminum 2-piece driveshaft and a new high-flow cat converter.
    DG
  9. #149
    I AM IMPORT POWER
    Driving Vicki Crazy
    I have heard that before. Once you do it a few times it becomes pretty easy though.
    -Chris
  10. #150
    - O - SIX -
    Colorado, USA
    It's way easier with a lift and a trans lift. I used to have one I could use all the time but now buy the time I get off work the shop is closed so I'm stuck doing it the oldshool way. It literally takes twice as long (about 3 hours) using the cherry picker.
    Mitsu did not want mortals to take apart the 3000gt and Stealth.
    Today I'll probably just stare at it, decide what has to go, and then go home.
