what is wrong with dsm coolers?
From what I've read there's a fair bit of pressure loss through DSM SMICs at higher levels of power
but shouldn't they be enough for any td04 turbo?
makes sense...but if I have the option I'd fit the biggest I can![]()
1996 GTO, Owner since 2003.
I know people say X amount size is "enough", but I see it like this; The colder I can make that air charge, the more power I am going to make. However, is there a point of diminishing return? Possibly, but I have no idea what that would be if it exists.
91 R/T TT
awesome. i'll take my intake charge at 200 degrees kelvin, please!
Nothing at all. When I made the DSM ones back in the day I offered them with oem pipes or 1 3/4" piping to mate up with the DNPerformance pipes as those start out as 2" but taper down to 1 3/4" on the ends. On my own car with stock bottom end/heads put down 441awhp on pump and 551awhp on race gas before running out of fuel pump using a piggyback setup. Those should work on 80% of the cars out there. I do believe the larger DN pipes made it flow better then oem which I'm sure helped alot.
DSM SMIC IC's -6 x 8 x 3-7/8" thick for a volume of 186 cu. in. each x 2 = 372 cu. in. total. Only difference with these and the Bell cores are that they're tube/fin design vers bar/plate.
Once I get done with a few projects of my own I'll be looking into making reasonably priced side mounts.
----------------[2007 Ride of the Year.................................. 3.5 Stroker I did.w/DBB DR1000's
