Page 1 of 13 12311 ... LastLast
Results 1 to 10 of 122
Thread: Why dont we have a good side mount option yet?
    Taichung, Taiwan
    Side mounts would be very beneficial to us. First, we are already setup to have them. You have lower pressure drop and they should be much more efficient than a front mount because there is nothing behind them to heatsoak. I know Gene made some but they are too big. I would much rather have stock dimensions with a much thicker core. This way you can use the stock ducting for great air flow. Anybody thinking the same?
  2. The Following User Says Thank You to VR-4 0wnz j00 For This Useful Post:
  3. #2
    Mankato, MN
    The SMIC vs FMIC thread has touched on this, but your only (reasonable) options are HKS ($1500) Dejon ($2000?) or Bell Intercoolers. If you can part with your stock sidemounts for 2 weeks, Bell will custom fab you a pair, and match the mounting hardware and piping to your existing setup, using any sized core (within reason). You can't really go TOO thick on the cores, before you start interfering with the stock oil cooler, pipe locations, mount locations, etc. There's not really a huge market in the 3S to support a big company designing something just for us, so you're left with small shops that will make a small batch at a time, or Bell, who are in business just designing and fabricating intercoolers.
    I was quoted $509 each, for an 8"x8.4"x3.5" core, and they're using a pair of stock IC's as a "template" for the pipe locations and mount points. Flow rate for each IC is 551cfm @ 10psi, with a 1psi drop across the core. Once I get them back, I'll post pictures and an impression of how they will mount up, but I won't have my car back until mid-April to test fit them. They're as close to the stock core "face area" as I could get, which should leave enough clearance around the sides to allow everything to line up even if they're not perfect. I'm hoping that they'll fit with the stock oil cooler and shrouding, but I'm prepared to tweak the oil cooler location and fabricate some ducting if I have to.
  4. #3
    you can custom order from bell. there's a thread about it on here already. (fmic vs. smic). you can put 4" thick smics in there if you really want to. you'll need to go with a FMOC and FMTC if you do that; they won't get any effective cooling sitting behind the smics.
  5. #4
    Taichung, Taiwan
    Wow that's cheap. Thanks for the info. Custom smics for that price is awesome.
    Quote Originally Posted by apickle View Post
    That is a good price. I gave up on using side mounts because of the price and I already had a front mount given to me for some work I did. Well....also I rot ripped off on some DSM ones so I just said screw it and went with the FMIC. I’d much rather had the side mount though.
    I assume they keep the template on file?
    Please ask them if they use a reference number or some other means to order similar parts to the same pattern without requiring physical examples. Once they build one set, you'd expect they could build more.
    ...and that says "group buy"...
    DG
  8. #7
  9. #8
    its kinda funny you say oil cooler wont cool effectively if you put 4" thick smic in front of it but the exact same thing happens when you put 4" core in front of your radiator
  10. #9
    this is straight up BS.
    chief among reasons that i say it is because a 2" radiator will cool MUCH better than a 3/4" thick oil cooler. additionally, if you're putting a 4" cooler in the sides, you won't have ANY room for an upgraded oil-cooler, if any.
    you're comparing apples to oranges here. same thing goes with FMIC vs. SMIC. until/unless someone posts up numbers for a 36x12x4" FMIC and 8x8x4" SMIC on an identical setup, then as far as i'm concerned, all the SMIC > FMIC talk is pure BS.
    /thread
  11. #10
    You understand how thermodynamics works, right?
    Any time you feed a cooler hot air, you reduce the efficiency. It doesn't matter if the downstream cooler is 3/4" thick or 2" thick, if you feed it hot air it won't cool anything.
    What is saving some many people with FMICs is that the airflow through the radiator isn't coming through the FMIC (because they aren't properly ducted) so there isn't hot air being fed into the radiator. The FMIC is acting more like cardboard across the inlet mouth than an actual heat source.
    If these FMICs were to be properly ducted, you'd see a drastic increase in intercooler efficiency, and a similar increase in overheated engines.
    DG
  12. The Following User Says Thank You to DG For This Useful Post:
