Page 1 of 4 123 ... LastLast
Results 1 to 10 of 39
Thread: Aeromotive Stealth Fuel Pumps, E-85 compliant and flow 350 LPH at 12.5V
    Banned J. Fast's Avatar
    - O - SIX -
    Colorado, USA
    Information supplied from Aeromitive Inc.
    Dimensions and style types:
    Pressure vs. Flow vs. Current Graph:
    E-85 Compliance Statement:
    Wiring Schematic and 1 year warrany statement:
    Stealth 316 Testing Information on Walbro 255 / Denso Supra / HKS / Bosch all at 13.5V:
    Aeromotive "Stealth" at 13.5v:
    Yes, two of them will fit in the tank on the stock hanger and don't require a hotwire.
    How noisy is this pump ?
    - O - SIX -
    Colorado, USA
    It's not noisier than a walbro that's for 100% sure.
    - O - SIX -
    Colorado, USA
    They are roughly $120 each, flow 340lph at 43psi base pressure, and have a 1 year MFR warrany.
    Medford OR
    I'd like to see that work...
    the BOSS of jellow supporter
    May 2005
    Dairyland
    if two will fit..... I guess I'm interested. would 2 of those support some like 780cc+ and e85?
    Those, who stand for nothing, will fall for anything.
    On the Internet you can be anything you want. It's strange that so many people choose to be stupid.
    i really would like to hear what the noise level is compared to the supra pump. $80 premium per pump is pricey; especially when you're "downgrading" flow ability. then again, i'm about to lose my mind with the walbro, and if i'm going to have dual pumps--i need it Q.U.I.E.T.
    at $120 each, you're telling me that IPS has a $25 markup on these?
    Charles Town, WV
    If the pump doesn't require a hotwire, it should still benefit from the normal hotwire resistor and relay bypass. More volts at pump = more flow, but it is pretty cool if it can just drop in and go so you don't have to do all the wiring & pump replacement at once.
    At $120 and 340lph, I *really* want to see a real-world bench test on how this works. And compared to those "kyosan" pumps that were supposed to be uber-leet, but flowed between a stock pump and a walbro, yet claimed outrageous flow specs.
    1995 VR4 Coupe
    -BOOSTTD- verified
    Elko, Nevada, United States
    If results match their flow tests I would be impressed, especially if not hotwired.
    That sounds like a damn good pump if it's not flaky numbers. I've heard of one or two Evo guys running them, but never saw numbers or reviews.
