Results 1 to 2 of 2
Thread: T Bolt Clamp sizing chart .. Thread for reference only
    Member
    Coastal Delaware
    I saw this great info and I just wanted to post it up for all to have quick access too !!
    Clamp Size Clamping Range, inches
    2.00" 1.87" to 2.12"
    2.25" 2.06" to 2.37"
    2.38" 2.19" to 2.50"
    2.50" 2.31" to 2.62"
    2.62" 2.43" to 2.74"
    2.75" 2.56" to 2.87"
    2.88" 2.66" to 2.97"
    3.00" 2.78" to 3.09"
    3.12" 2.90" to 3.21"
    3.25" 3.03" to 3.34"
    3.50" 3.28" to 3.59"
    3.75" 3.53" to 3.84"
    4.00" 3.78" to 4.09"
    4.25" 4.03" to 4.34"
    4.50" 4.28" to 4.59"
    Notes: - Please read before ordering -
    1) For 3PLY (thick) coupler typically you would need 1/4" larger Tbolt clamp for the size of pipe you need, for example if you have a 2.0" ID silicone coupler you will need to purchase a 2.25" tbolt clamp in order to compensate for the extra silicone.
    For 4PLY (thick) coupler typically you would need 3/8" larger Tbolt clamp for the size of pipe you need, for example if you have a 2.0" ID silicone coupler you will need to purchase a 2.38" tbolt clamp in order to compensate for the extra silicone.
    Check the clamping range to make sure that the clamp will fit your silicone hose.
    2) How to figure out the outside diameter of the hose: Inside diameter + 2 x thickness of the hose .
    Puts out on 1st date verified
    October, 1999
    San Antonio, Tx
    Here's another good reference.
    Breeze T-Bolt Clamps
    2021 Charger Scat Pack (Bright White) - Speed Machine
    2018 Jeep Wrangler Rubicon (Billet Silver) - Rock Bouncer
    2014 Ram 2500 Cummins (Bright White) - Tow Truck
    U.S.M.C. 10/87 - 10/93 SEMPER FI
