Page 24 of 26 FirstFirst ... 142223242526 LastLast
Results 231 to 240 of 259
Thread: Gauging Interest: Turbo rebuilding and Upgrading 9b to 13G, 15G, 19T
  1. #231
    Quote Originally Posted by Midwest Turbo Connection View Post
    Okay, it would be best to have them match. There is a small difference in the size of the turbine wheel that would create an imbalance in air flow. If you want to send them in to us we can evaluate what you have. If the current combination turns out to be less than ideal we could always trade you a TD04 13G so you would end up with a matched pair. Thanks.
    I'll remember that - thanks!
  2. #232
    they are most likely both TD04L. The compressor housings on a lot of non stock 3/s 13Gs are mis-stamped.
  3. #233
    The "TD04HL" is cast, not stamped...my understanding previous to this was that the housings were essentially the same, but the wheels were different.
  4. #234
    yes I know it is cast into the compressor housing, I've had a few DSM 13Gs that said TD04HL, they were actually td04. Mitsu used whatever compressor housings they had laying around when they assembled them.
  5. #235
    I remember reading that somewhere - that the housing were the same; weren't the true HLs (HL wheels, I mean) available on Saabs or Subies or Volvos or something?
    A true thru-and-thru TD04HL turbo flows quite a bit more than the DSM housing-only version, right?
  6. #236
    As far as I know no genuine mitsu 13g was ever tdo4hl.
    The optional factory 13g upgrade was td04l.
    Volvos came with 15g and 19t td04hls
    Close to 600awhp has been made through 19t td04l turbid.
    I do not think the l turbine is a bottleneck for 13g size turbos. Anything larger will only add more lag
    Sent from my DROIDX using Tapatalk
  7. #237
    You are right on the 13G being paired with the TD04HL. The TD04HL's used a 13T wheel as opposed to the 13G. The 13T is a superback wheel and the g is a flatback so that would need to be taken into consideration with a rebuild kit.
  8. #238
    Okay - so probably best to look for another TDO4/13G to optimize things, right?
  9. #239
    how you actually measured the turbine? What I am saying is they are probably both Td04.
  10. #240
    That's what I'd recommend. If you end up wanting us to do the rebuild we will trade your TDO4HL for a TD04. We have all the specs so if there was any question after a visual inspection we can take the exact measurements and could let you know. Thanks.
