Originally Posted by
Lugnut
Yeah we did leave them in .. And the reason was
A. If we cut into the stock housing we werent sure how the plastic was gonna react to being cut or dremeled out .. There was the possibility it might not have turned out looking very clean ..
and
B. The only blocked view is the first number on the temp gauge, and since the other two numbers are easily readable its not an issue whatsoever .. You can see either 80's-90's or 00's-20's .. On another note, I just realized I didnt post a picture of it but we also have the Wideband mounted right behind the steering wheel on the column .. Its dead center and very in your face so you can see everything happening in the car all the time !!!
