both windows stopped working and the button by the cigarette lighter that adjusts the seat doesnt work
but
the seat does move forward and backward
i already checked the 30A fuse under the hood and its fine
any ideas?
but
any ideas?
Couple of things to check:
1) Here is a good list of ALL fuses in the car:
http://www-personal.umich.edu/~btlarson/fuse/index.html
2) IF you disconnect the Power Window Switch on the drivers door, it kills both door switches/windows. Make sure the connector to the drivers side switches isn't loose.
All wires from the main panel controlling the windows/locks etc go through a large harness by your drivers door hinge. I've been told (and seen) these wires get old and brittle and break......not easy/cheap to repair. But all your window/lock controls go thru that harness.
3) The wiring for the driver seat is under the carpet below your seat. Passenger seat is manual.... Check connectors under seat and all fuses.
thanks a lot.
i checked the diagram and it ended up being the relay for the power windows.
i had let my bro borrow it and i guess he must have kicked it loose
now the power windows work and the seat adjuster does as well
thanks again!!
I'm having the exact same problem as Illmatic Enzo, but the link (http://www-personal.umich.edu/~btlarson/fuse/index.html) is broken. How did you end up fixing the problem?
Waiting install
Build Thread
lol, I'm glad someone got use of my doc. I graduated so the link was taken down. I'll have to find a new place to host it.
B-Man, did you get a chance to re-host it somewhere yet?
No, but PM/Rep me your e-mail and I should be able to sent them to you if you still need them.
