Results 1 to 10 of 13
Thread: boosting issue
    boosting issue
    Im set up to run 14 pounds of boost on stock turbos. I just replaced the heads,turbos,y-pipe and gutted the cats. I just got the car back yesterday so i have not pushed her hard at all. As i was coming home from the shop and getting on the interstate i gave it some gas and as boost began to build the car just nose dived i guess you could call it. The engine stuttered and acted like it just gave up. My first thought was over boost. My gauge was reading 25 (aftermarket pro-sport) pounds(dont even think 9b's can spike 25 lbs lol). I pulled over immediately and turned the mbc almost all the way down. as i was getting back on the highway i babied her up to speed. in 6th i tried again and same result. this time i heard a loud whistle under the hood. Any ideas... my first thought was a massive boost leak.
    Oh i did replace some things this morning as well. i replaced the rear o-ring on the rear turbo pipe and the vac caps that were dry rotted. This killed the whistle but not stalling during boost
    And 1 thing i did notice is i can ease into boost a little bit but not full throttle.
    Things i have done to car when it went down.
    fairly new 9b's from a jdm engine
    vac reduction
    y-pipe
    gutted cats
    SKADOOSH!!! verified
    Prince George
    Check your wastegates pressure, do a pressure test on your intake, had you done anything to do with fuel? In the simple mind thoughts I had it sounds a lot like fuel cut?
    Also, what year is your car? check into your TPS, and CAS.
    Photobucket
    no pressure test yet...
    as far as fuel its all stock system. with the boost set at 7 pounds it dont fuel cut as often.
    My mechanic that worked on it to get it running said the same thing a fuel cut.
    tps and cas rings no bells can you explain a little?
    Quote Originally Posted by Ok3skid1 View Post
    throttle position sensor and cam angle sensor.
    1991 3000GT VR-4 for fun
    1993 honda civic hatch for every day
    Boost leak classic.
    i turned the boost controller way down. My gauge showed a total of 7 pounds of boost the last time i boosted. Now i cant hold 2 pounds without a bunch of air escaping from some where. It sounds horrible. maybe my blow off valve
    Loveland, OH
    Spark Blowout..
    Replace coil packs and/or wires or perhaps the PTU..
    Quote Originally Posted by MightyMouse View Post
    Spark Blowout..
    WTF, do you even read what is posted?
    You need to get a pressure tester and start finding your leaks. From what you are posting it sounds like it's a major leak at a connection point.
    of course i read it... Why would i ask for help and not read anything
    Im in the process of building a pressure tester...
    as far as the ptu and coils both were pulled and tested during the process of putting motor back together from head job. They both tested good but i dont know enough so im not saying there not my problem still.
