Ok, I've got logs, but I can't upload an excel file...I changed the file extension, and the size exceeds the forum limits as well...
I was crusing the parkway, luggin' it in 5th gear for awhile, then dropped to 3rd to make a pass on a semi and I just held the gas on to see what would happen, it threw a CEL and when I pulled the code, it was O2 sensor and after looking at the logs, it looks like the front O2 has some low voltage readings, but I'm new to reading logs and knowing what to look for...
While under a load, your o2 should be 0.93v-0.95v.
Use some file upload service.
http://www.mediafire.com/?fhfa7ubsa6boj8i
http://www.mediafire.com/?byeiszyeh1uvbwf
http://www.mediafire.com/?p78amm7v240f047
http://www.mediafire.com/?u3pxo33e0g9wc50
There's the logs, Yeah, I'm sure it's the O2...
TBH, I cant really tell what is wrong, but it looks like the o2's are fine from what I can tell.
There is no knock, so there is no timing retard.
it threw an O2 code for a second, and looking at the logs, the front O2 drops down to .04v which seems low and I'd think the front and rear would be in the same ball park area together.
I don't know though, I'm no proffessional with reading logs
thought I'd update this, just incase anyone ever has anything similar happen to them...
Yeah, the O2's looked normal, everything I logged was while driving, then, as I was checking some things in the driveway, I noticed the rear O2 sensor was stuck at .8- volts and not oscilating like it should...O2 was bad, I threw in two new ones and the car runs perfect...I should have caught that A LOT sooner...I feel retarded...
Makes sense now that I think about it, ran great in boost since under a load the O2's go open loop and it was stuck in open loop, which also makes sense as to why it'd backfire when you let off the gas...fuel cut wasn't happening on the rear bank
Anyway...thought I'd post up results, I hate topics with no ending ha
Thanks for the update...in currently having the exact same problem, gonna check out the O2's now
