Thought this was a commercial for a Japanese baseball team at first, but there's a surprise at the end. On a side note, the chick at the end has got a nice swing!
2013 NG: 1st place, FWD Drags
This. Changes. EVERYTHING.
KILSWITCH Android tablet delivers airstrikes in four minutes
'92 Dodge Stealth SOHC - 3SX Adjustable Camber & Toe Arms, Eibach Springs, KYB Struts, 3SX Steel Braided Brake Lines, Stillen Brake Pads on Stillen Cross-Drilled Rotors, 3SX Steel Braided Clutch Line, 3SX Lightweight Aluminum Crank Pulley w/ Gatorback Belts, 65mm Big-Bore Throttle Body w/ Half-Shaft Mod, ARP Head Studs, 3SX Poly Motor Mounts, 3SX Short-Throw Shifter w/ Solid Shifter Bushings, Single TD05H 20G, FMIC, FMOC, Hotwired Walbro 255, 525cc Precision Injectors, 3SX underhood fuel kit w/ Custom SOHC Fuel Loop, Custom Ceramic Coated Headers and Turbo Downpipe, RT High-Flow Cat, Custom Stainless 2.5" Cat-Back w/ Flowmaster 40, Spec Stage 3 Clutch, Fidanza Light Weight Flywheel, Various GM Sensors, Innovate LC-1 Wideband, Tuned with MAPECU 2.
I seriously hope you are joking, because if you're not, your voting privilege should be revoked permanently.
Ask ANY army grunt who has been under enemy fire what his thoughts on CAS are. This is a FANTASTIC breakthrough, one that will save lives and enable quicker response times. If you honestly think this is DEmotivating, you're either a Daesh sympathizer, or in need of serious psychiatric help (or both).
https://www.kickstarter.com/projects...nd/description
I just jizzed in my pants.
Actually, I'm neither a sympathizer or in need of mental help. Just smart enough to realize that the US is once again fighting battles that they have no business fighting.
This "fantastic" new tool just makes it too easy to wage war, in my opinion.
Time to stop wasting human lives? I think so.
