Page 711 of 892 FirstFirst ... 211611661701709710711712713721761811 ... LastLast
Results 7,101 to 7,110 of 8916
  1. #7101
    Feb 2011
    Scottsbluff, NE
    Interested to see what it looks like when you're done.
    1995 Dodge Stealth R/T Turbo
  2. #7102
    STL, MO
    Indeed!
    1991 Stealth RT/TT
  3. #7103
    Never finishes any verified
    Wake Forest, NC
    I got the inner tint layer on. Camera phone does not do it justice. tomorrow I hope to get the final clear on and then wetsand/polish in the next couple days.
    Check it out on Youtube!!
    Chrome ECU
    Hybrid 13g's
    EVO 560cc Injectors
    Spec Stage 3 clutch
    CX Racing Dual Core FMIC
    Megan SS Exhaust
    3rd Gen Lifters
    Maximal High flow converter
    Walbro FP & FuelLab FPR
    All -6an Lines
    AWS/ABS/Cruise Delete
    MP Rear Control Arms
    SS Brake Lines
    99 Front Conversion
    2nd gen Rear Bumper
    99 Combat Wing
    Complete interior LED Swap
    Skillard Fuel channel
    Oohnoo FPR Bracket
    More to Come......
  4. #7104
    Sick!
  5. #7105
    STL, MO
    Fuck yea! Want a set, how much?
  6. #7106
    Wake Forest, NC
    Let me finish them first... Damn Coyotes...LOL
  7. #7107
    yep. precisely what i need to do my garnish too.
  8. #7108
    I don't bite
    Southern IN
    What did you do today to your 3/S?
    Built a catch can this weekend. Trying something new by having 5/8" OD alum tube fixed in valve cover and catchcan and will just used 5/8" hose and hose clamps instead of AN fittings (I was tired of the AN swivel fittings getting sticky.) Bought a 5/8" tube bender just for this project
    Engine bay is a bit of a mess right now, but should look somewhat tidy once it's all back together.
    One vacuum source (The other vac source is the exhaust)....
    Hung the pistons on rods last night. Hopefully have time this weekend to finish assembling the engine, time, degree, check piston to valve and re-time. Also need to pull the mock-up engine and trans so I can "build" the trans (upgrade clutches and shift kit).
  9. #7109
    Mar 2014
    x
    St. Louis
    Very cool. This build excites me. What did you do the welding with? Looks like a spool gun maybe.
    Project LS3S - '94 Stealth
    - Build thread on 3si http://www.3si.org/forum/f1/mdoe8s-n...72/?highlight=
  10. #7110
    I don't bite
    Southern IN
    Was actually a TIG. My fitment of panels wasn't great (angle grinder fab tool) so I had to glob on the filler to make sure it sealed up tight. The "stack of dimes" looked like it was stacked by my 3 year old, so I went over many of the seams with the torch to smooth it out. Catch can is not a structural piece, so wasn't concerned about reheating it. (Not even sure that's a concern with aluminum like it is with stainless.)
    Bottom line, I'm not a pro welder that turns out the welding artwork that I drool over on the interwebs But, I built it and it should function they way I intend with vacuum being pulled by turbo and exhaust (moroso exhaust crankcase evac kit) . (BTW, when someone charges $100-200 for a catchcan, that's a steal. This thing took FOREVER to cut and weld all of the components inside and out!)
