Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 36
Thread: Rear Steering Rack Rebuild
    JNS Engineering verified
    San Jose, CA
    I have no doubt I could draw up the needed tool in AutoCAD. I just think the small (3mm) pins would break off before anything would turn on that end. Either something interferes with turning the end cap or it's welded shut. There's a right angled block with a hydraulic connection so I was thinking that piece was threaded in to the cylinder housing and might be blocking the end cap from turning however the right angle piece doesn't budge either.
    San Jose, CA
    Well, I didn't use a big enough BF pipe wrench after all
    I found a hydraulic shop today and brought in the power cylinder. They used a really huge pipe wrench and opened it up and replaced the shaft seal for FREE !!
    It was already completed when I returned and I asked him how he did it and he demonstrated that it functions properly and has no leaks. So, my core unit is fixed already and I have the one on the car to take out and fix. If this core unit can be cleaned up enough I might put it on my car.
    I didn't get the PN of the seal they put in there but I do have the one they pulled out. It states SKY-18N on the seal but google returns nothing on that. Anyway I'll probably take mine down there and see if I can get it done for free too!
    Ask if you can get seal PN info! That would be awesome for those looking to do the same in the future.
  4. #24
    San Jose, CA
    Yes, I will try. The seal is kind of similar to what we have for the cams and transmission shafts, not like an O-ring at all.
    I was thinking the way to open up the power cylinder is to do it on the car when it's still bolted to the subframe. It takes a pretty huge vise to hold it otherwise.
  5. #25
    Do you think it's similar to anything in the front rack? I've rebuilt those a couple times but I imagine they are different pns.
  6. #26
    San Jose, CA
    Nope, just looked at the front rack rebuild wiki and nothing there looks like the seal in the power cylinder. I'll get the info on it next time though.
  7. #27
    Good info. I don't plan on deleting my rear steering, so any info to rebuild them if needed in the future is gold!
    -Benn
    Master Elite KIA Technician
    Follow my build thread here
  8. #28
    San Jose, CA
    I have all the details on the seal
    I went back to the hydraulic shop and found out what the original seal is and what the replaced it with. I bought a couple of seals so I have one for my power cylinder and I have a spare one. Haven't been able to locate an on-line source for these though. I may go setup a group buy on these seals.
  9. #29
    San Jose, CA
    What I know is the original seal is Nitrile Rubber (aka NBR or BUNA-N) and the dimensions are 18mm inner and 26mm outer and 5mm thick. Essentially a small rubber doughnut.
    The profile of the seal is called SKY.
    The shop I used installed new seals of a different profile. The ones they used were Polypak Type B which is similar to SKY but capable of higher pressure sealing. The Polypak technology uses what they call an energizer ring kind of like an O-ring to support the lips that seal against the rod and the bore.
    I bought two extra seals from them and plan to take my power cylinder apart and replaced the seals. I plan to leave the cylinder mounted in the car and use a large pipe wrench to unscrew the end cap after removing the tie rods.
    I never could open the old cylinder because I don't have a vice and couldn't get a good grip on the end cap.
    Anyway if you have a southern car that isn't rusted to shit there is a way to keep AWS and its fairly inexpensive. Just replace the seal(s).
    BTW nitrile rubber is very good at sealing hydraulic cylinders however it is not expected to retain its properties for 20 years. I don't think we could fault the designers one bit for using it.
    I've googled extensively for metric rod seals and have come up empty for on-line ordering. What I have found so far is:
    CRC Seals: MPP-018.0x026.0x05.0B
    Hydraulicseals.com.au: SKYM-018026-05
    I haven't tried contacting them by phone.
  10. The Following 3 Users Say Thank You to Jimvr4 For This Useful Post:
  11. #30
    This should be stickied or something for the future!
