Results 1 to 6 of 6
Thread: WTB td04 CHRA and Hotside
    Crimson Jihad Not Verified
    Hey guys looking to pick up a pair of td04 CHRA and Hotsides for a turbo rebuild. I know a lot of people started using the kinugawa 19t/20t so they may possibly have their 9b CHRA's available. If you have a set of complete 9bs I maybe interested in those if no one has the seperate components available.
    CAUTION: Over Boosting May Cause Accidental Orgasm.
    1993 Mitsubishi 3000gt VR-4
    May 2013
    union, ky
    I have about 5 laying around, and I'll let you know how much power the 20t's from kinugawa get me ;b
    Sent from my HTC0P3P7 using Tapatalk
    Engine mods: Duralast Gold battery, HKS SSQ BOV, K&N Cold Air Intake, 3SX custom Y-pipe, Megan downpipe-back exhaust ,EGR delete ,vacuum delete, turboxs mbc at 10psi, msd 8.5mm spark plug wires, denso iridium spark plugs
    Wheels: 17x9.5 Rota Grid fitted with bridgstone tires 225/35/17
    At least my jackstands are reliable Not Verified
    Rochester Hills, Mi
    Quote Originally Posted by Art Of Jammin View Post
    You should make a thread with your build. I'd be very interested in reading about your experiences with the Kamak 20ts.
    95 Base 3k: 6G74/TT/AWD conversion
    May 2013
    union, ky
    I plan to once it is finnished, it has been a nightmare so far, let me put it this way, just finished the whole engine put everything together, started the tuning processes....... Then boom! Cylinder one's ring decided to go out on me v.v I'll start a thread once I get a chance tho!
    It never is as easy as they say, but then again no one ever says its easy with these. I finally got my car running great with the 13ts I have and am doing general maintenance to make sure everything that needs to be replaced is replaced. I want to build these for next winter so I can swap them out for 20t's or bigger... Looking forward to your progress. Also sent you a pm about those parts you got laying around
    May 2013
    union, ky
    I'm quite a but into this build and finally decided to go ahead and push it to its max, buying stuff for e85, meth injection, and should top out pretty high.
